August 29, 2026, 09:08:44 pm
Hoffman Amps Forum image Author Topic: On-On Toggle switch wiring  (Read 5847 times)
Offline Wonder2121
« on: November 24, 2023, 04:53:33 am »
How do we wire toggle switchs?
2 seperate input channels
DPDT on-on switch
Re: On-On Toggle switch wiring
« Reply #1 on: November 24, 2023, 05:53:46 am »
That works. You could have used a SPDT switch.
Offline Wonder2121
« Reply #2 on: November 24, 2023, 06:41:50 am »
Any reason your duallite looks different, would copying your schem work using those grounds?
My switch is on/on DPDT or should it be SPDT?
« Reply #3 on: November 24, 2023, 07:12:44 am »
Well your simple diagram is only using one half of the switch, ie, one pole. Therefore a SPDT would do the job.
It's not clear if the "HOT" lead is an input or output. If it's an output and the CH1 and CH2 are coming from, for example, two preamps that you want to send via the HOT to a phase inverter then your simple drawing works just fine.
But if the "HOT" lead comes from a single input jack that you wish to send to either CH1 or CH2 preamps, then wire the DPDT switch as shown in my Dual Lite. By wiring the other pole center lug to ground and cross connecting the outside lugs, the unselected CHANNEL input will be grounded, keeping the noise down on the unselected channel.
Offline Wonder2121
« Reply #4 on: December 18, 2023, 10:43:03 am »
@sluckey
I wired your PPIMV mod for dual lite
http://sluckeyamps.com/dual_lite/dual_lite.pdf
My cut is acting like a volume more than cutting any frequencys...
Its wired exactlly as suggested...flummoxed why, any ideas?
« Reply #5 on: December 18, 2023, 12:07:11 pm »
Works on paper. Did you try the cut pot before you added the MV? Turn the MV all the way up. Does cut work now? Did you use a .0047µF cap? Are you sure it's wired like the drawing?
Offline Wonder2121
« Reply #6 on: December 19, 2023, 10:13:01 am »
Problem solved, must have been soldering error on my behalf...(Don't know what I'd do with out this forum)
Build nearly finished in time for Xmas
:m12
« Reply #7 on: December 19, 2023, 11:05:44 am »
What did you do?
Offline Wonder2121
« Reply #8 on: December 19, 2023, 04:53:35 pm »
What did you do?
May have overheated 4700pf poly cap, was cutting in and out on wiggle in conjunction with weak solder joint no doubt....
« Last Edit: December 20, 2023, 02:18:30 am by Wonder2121 »
