August 29, 2026, 09:10:36 pm
Hoffman Amps Forum image Author Topic: Hoffman Plexi 50 mods  (Read 5117 times)
Offline Jhj
« on: December 15, 2023, 05:15:02 pm »
I recently completed a Hoffman 50w Plexi. It works well but needs a bit more “bite”. I added a bright cap to channel 1 (47pf) after trying a 500pf.
What else can be done? Anything with the NFB? Move it to the 4ohm connection, perhaps?
Re: Hoffman Plexi 50 mods
« Reply #1 on: December 15, 2023, 06:27:29 pm »
Hoffman Amplifiers Plexi50 – with Hot Switch Gain Mod
Offline stratomaster
  • Don't guess, measure.
« Reply #2 on: December 15, 2023, 06:50:34 pm »
Try a 56k for R16 if you're just looking for more high end.
I assume you've tried jumping the channels?  If not, put a jumper wire between pins 2 and 7 on V1.  This will activate both volume controls.  Acts as a gain boost and an eq.  People normally turn up channel 2 for dirt and bite and just turn channel 1 up enough to fill out the low end.
Failing that, there are entire companies formed based on the modification and perfecting of this circuit.
I think these two suggestions are a good start.
Offline dwinstonwood
« Reply #3 on: December 15, 2023, 08:51:39 pm »
As sluckey said, try using the Hot Switch mod. I wired it always on in the one I built.
And,  what stratomaster described sounds worth trying, too. And, probably less trouble to add!
[edited to remove my PDF that has errors]
« Last Edit: December 16, 2023, 01:59:31 am by dwinstonwood »
« Reply #4 on: December 16, 2023, 08:04:10 am »
Offline Jhj
« Reply #5 on: December 16, 2023, 05:16:42 pm »
I had considered the hot switch mod and may still decide on that direction. However, internally connecting the V1 inputs is a great suggestion that I’ll try first.
I’ll report back. Thanks.
