September 14, 2026, 04:58:49 pm
Hoffman Amps Forum image Author Topic: New Jtm45 hums  (Read 10235 times)
Offline James_Wildart
New Jtm45 hums
« on: December 16, 2023, 01:40:13 pm »
I just finished building a Jtm45 clone, I used a TR-PW-05 power transformer. When I flip the Standby switch all I get is a loud hum and nothing from the guitar. Seems like I have all my wiring correct but I must have something wrong. What do you suggest I look at first?
James  :dontknow:
Re: New Jtm45 hums
« Reply #1 on: December 16, 2023, 01:46:56 pm »
If it was wired correctly, it would likely be working.
1) Can you show us a schematic of exactly what you have made.
2) Have you checked voltages of tube plates and cathodes?  Can you post that?
3) Can you post detailed pictures of the amp build.
4) Have you tried another guitar, guitar cord to amp, and speaker?
5) Have you tried different tubes known to be good?
It is easier to help you IF you give us this information that we normally will ask for.
Re: New Jtm45 hums
« Reply #2 on: December 16, 2023, 06:36:22 pm »
That is very popular. So popular that Doug posted about it.
How to double check your amp wiring and find things you missed
"Hoffman's law states the the amp would be working if everything was correct"
https://el34world.com/Forum/index.php?topic=17701.0
« Last Edit: December 16, 2023, 06:38:29 pm by PRR »
Offline Brownie
Re: New Jtm45 hums
« Reply #3 on: December 17, 2023, 04:28:54 pm »
Maybe double check the wiring at the input jacks. The tip or inner of your cable may be going to chassis ground if it's a shielded cable such as RG174. Sometimes the inner gets melted or soldered to the shielding
Re: New Jtm45 hums
« Reply #4 on: December 18, 2023, 09:32:58 pm »
What I am trying to do is combine two layouts since I have the TR-PW-05 transformer. A regular Ceritone jtm45 layout and a Jtm45_Plus layout I got on Tube Depot. This layout uses the TR-PW-05 Power transformer. I just want to wire it real simple without a Master Volume. I'll get the voltages of the Tube Plates and Cathodes tomorrow.
The Tubes are brand new Mesa Boogie's and Mullards 12ax7's, Genalax remake KT-66 power tubes and a Mesa 5Y3GT rectifier tube.
I'll try and get more pics too, I know it's hard to see whats going on.
Thanks so much, I actually like trying to figure what's wrong with it more than building it in the first place.
Offline Esquirefreak
Re: New Jtm45 hums
« Reply #5 on: December 18, 2023, 09:38:30 pm »
I'd use ONE layout. And a GZ34 rather than a 5Y3.
/Max
Offline Latole
Re: New Jtm45 hums
« Reply #6 on: December 19, 2023, 03:12:25 am »
Most of the time, hum is from a bad ground or a ground missing or a bad solder on a ground wire(s) ,
Re: New Jtm45 hums
« Reply #7 on: December 19, 2023, 03:51:01 pm »
I just heard an amp tech say he's fixed a lot of amps by just tightening some ground lugs.
Offline Latole
Re: New Jtm45 hums
« Reply #8 on: December 20, 2023, 03:03:55 am »
Anything to do with the ground must be suspected.
But in the case of a new construction, who knows what assembly errors could cause this hum?
In the case of an amp that has already worked perfectly, trouble shouting is simpler and follows a certain logic.
Which is not the case here.
Re: New Jtm45 hums
« Reply #9 on: December 20, 2023, 05:37:34 pm »
So I went around and tightened all the lugs that went to ground and got the hum down to a low purr but still no sounds from the guitar and smoke started coming up from one of the power tubes. I flipped it over and the 1K 2watt resistor was burned.
I attached a pic
Another odd thing...I have the pilot light hooked up to the power switch and when I plug the amp in the light comes on before I swtich it on. When I switch the amp on the light goes off, how can that be?
Re: New Jtm45 hums
« Reply #10 on: December 20, 2023, 05:43:36 pm »
Pilot ain't wired correctly. Probably same issue with no sound/smoke issue.
Offline Latole
Re: New Jtm45 hums
« Reply #11 on: December 21, 2023, 04:39:15 am »
From the beginning we know there are many wiring mistake.
OP must check his work more carefully
Offline Ronquest
Re: New Jtm45 hums
« Reply #12 on: December 21, 2023, 06:29:52 am »
I'd like to add, this is can happen with an IEC socket that's miswired "AND" IEC chords that are wired with the hot and neutral reversed.  I have a pile of factory chords that are cross wired.  I started testing my chords after having my LED lamp light in the off position once when I switched chords.  A surprising amount are crossed.  Guess this isn't a problem for some devices, but in an amp, it's not good!  Especially considering if your working on it.   However my amp lamp now tells me if the outlet or chord are miswired.  This is also a good example of why double pole switches are a good idea.
Re: New Jtm45 hums
« Reply #13 on: December 21, 2023, 06:44:02 am »
Please provide clear photos showing where each wire from the pilot light is connected.
Please provide the specification of the pilot light, as both layouts show a 6.3V type, intended for connection to the 6.3V heater circuit.
Offline Ronquest
Re: New Jtm45 hums
« Reply #14 on: December 21, 2023, 06:57:41 am »
Looks like the 120V pilot light is wired to both sides of the power switch!  That could be your light problem.  One lead to the switched side and the other to ground.
« Last Edit: December 21, 2023, 07:13:22 am by Ronquest »
Re: New Jtm45 hums
« Reply #15 on: December 21, 2023, 07:07:12 am »
No! Never ground. That indicator lamp should be wired to the same place as the PT primary wires. IOW, parallel to the PT primary.
Offline Ronquest
Re: New Jtm45 hums
« Reply #16 on: December 21, 2023, 07:18:21 am »
Your right!, go to fix one issue and make another.
Offline Latole
Re: New Jtm45 hums
« Reply #17 on: December 21, 2023, 07:27:25 am »
If you had revisited your circuit as suggested several times, you would have seen this problem and all the others.
Offline JPK
Re: New Jtm45 hums
« Reply #18 on: December 21, 2023, 08:06:37 am »
In the two layouts you posted I see a pilot light wired to the 6.3V filament supply. I'm not seeing any pilot wired to a power switch. So yeah pilot light wired wrong sounds about right.  :w2:
I love tubes
Re: New Jtm45 hums
« Reply #19 on: December 22, 2023, 08:45:30 am »
So are you also saying that I could have the IEC female plug upside down making the wiring backward and that's what's making the Pilot light go on?
Re: New Jtm45 hums
« Reply #20 on: December 22, 2023, 11:54:31 am »
That's not why the pilot is misbehaving. The pilot is wired incorrectly. The fix is very simple. Look at the attached pic to see what you have to do to make it work correctly...
Re: New Jtm45 hums
« Reply #21 on: December 22, 2023, 12:13:43 pm »
Thanks, I went ahead and attached it to the heaters like the layouts show. I had an amp tech for a somewhat famous guitarist tell me to attach it to the pilot light.
I also flipped the IEC plug around to see if that makes a difference.
Re: New Jtm45 hums
« Reply #22 on: December 22, 2023, 12:19:37 pm »
That pilot lamp will not work when connected to the filament circuit. It is intended to be connected to the 120VAC.
Re: New Jtm45 hums
« Reply #23 on: December 22, 2023, 12:48:04 pm »
Well I have great news, whatever I did fixed it! I now have sound from the guitar! But I also have some little pops and crackles I need to clean up.
And you are right Sluckey that didn't fix the pilot light wiring it to the heaters so I'm taking your advice and wiring per your instructions.
Re: New Jtm45 hums
« Reply #24 on: December 22, 2023, 01:11:47 pm »
The pilot light works perfectly now! Thanks
Re: New Jtm45 hums
« Reply #25 on: December 23, 2023, 04:58:29 pm »
The amp is amazingly quiet except when I turn it to 10 a very low hum ...now I'm off to Youtube figuring out how to bias it.
