August 29, 2026, 09:12:51 pm
Hoffman Amps Forum image Author Topic: Comparing front ends  (Read 4187 times)
Offline pbman1953
« on: December 18, 2023, 04:06:13 pm »
I have  Super twin amp and Studio Bass amp.
Both are very similar, and one was made as a bass amp and the other a guitar amp
I see on the front end of each there a few different values used so I'm wondering what the values would do the sound.
Studio Bass-V1A- 7025A- pin 6 goes to a 330 K and a .0012 cap
Super twin- V1A-7025a- pin 6- The difference on this is that there's a 100k and a 330 pf combination
Studio Bass-   7025b-  pin 3-   has a 2.7k to ground
Super Twin-  7025b-  pin 9 has a 820 ohm on the Reverb Model , but a 1900 ohm on the non-Reverb model
Studio Bass- v3 12ax7- pin 7 to a 2.7k to ground. Pin 8  750mf cap & 1.5 k to ground
Super twin-   v3 12ax7- pin 7 to a 3.9k to ground. Pin 8  1mf cap & 1.5 k to ground
Offline pbman1953
Re: Comparing front ends
« Reply #1 on: December 19, 2023, 09:44:27 am »
41 views and no comments?
Offline acheld
« Reply #2 on: December 19, 2023, 10:08:06 am »
Your questions are rational, but there are a lot of them and going back and forth between two large schematics is a lot of work.
For the first comparison, the Studio Bass tone stack takes the frequencies < 100Hz down about 10dB.
Check out http://www.guitarscience.net/tsc/bigmuff.htm#RIN=1k&R1=39k&R2=22k&RM=100k&RL=1M&C1=4n&C2=10n&RM_pot=Linear and play around with the Tone Stack calculator.
Or, download the Duncan Tone Stack Calculator if you use Windows.
The second batch did not match up with the schematics.
Offline pbman1953
« Reply #3 on: December 19, 2023, 10:36:54 am »
So you're saying that the combo takes out 100hz before any anything?  Why would they take out so much?
Correction-
Studio Bass-   7025-v1b-  pin 3-   has a 2.7k to groundSuper Twin-  7025b-v1b-  pin 3 has a 820 ohm on the Reverb Model , but a 1900 ohm on the non-Reverb model
Studio Bass- v3 12ax7- pin 7 to a 2.7k to ground. Pin 8  750mf cap & 1.5 k to groundSuper twin-   v3 12ax7- pin 7 to a 3.9k to ground. Pin 8  1mf cap & 1.5 k to ground
The Super twin had 2 models, A Reverb and a non-Reverb model. My version was a combo of the 2 so maybe mine was made mid-way before they sold the Reverb. Mine doesn't have Reverb.
Thanks for this-
