July 25, 2026, 10:52:08 pm
Hoffman Amps Forum image Author Topic: PT wiring Hammond 270DAX  (Read 5968 times)
« on: December 20, 2023, 07:47:18 am »
Just wanted to double check something before picking up a PT for a project for a friend.
When I've used Hammond PT's in the past, they have typically been listed something like 260-0-260 @104ma.
Yet this 270DAX is listed as 520CVT @104ma.  I'm not understanding why they list it that way instead of 260-0-260?
I plan to use a solid state rectifier to save room on the chassis. Build will be around the size of a Princeton Reverb.
My understanding is the red/yellow wire on the PT would be grounded to chassis and this is not an "internal wire" but actually an external wire grounded to the chassis.
Q1) Is the way I have drawn the schematic correct for using this PT?
Q2) Using the 260v x 1.4 (solid state rectifier) would the 364v on node A be a reasonable expectation?
Thanks, Tubenit
Re: PT wiring Hammond 270DAX
« Reply #1 on: December 20, 2023, 08:09:59 am »
AFAIK Hammond has always listed their transformers as 520V C.T. rather than 260-0-260. Both methods of expression are exactly the same. Look here for an example...
     https://www.hammfg.com/electronics/transformers/classic/200
Schematic looks fine. And you should expect 364VDC unloaded B+.
« Reply #2 on: December 20, 2023, 08:14:09 am »
Always grateful for your excellent help and advice, Sluckey!  Very appreciative.  Thank you!
« Reply #3 on: February 11, 2024, 12:32:46 pm »
I am thinking this 270 DAX  6.3v wiring does NOT have an internal center tap ground?
Is that correct?   I was planing on an artifical CT using 100 ohm resistors.
with respect, Tubenit
Offline Ronquest
« Reply #4 on: February 11, 2024, 12:42:39 pm »
Hammond shows, NO center tap for the 6.3 winding and only green to green for wiring.  Same with real pictures I've seen.
« Reply #5 on: February 11, 2024, 01:52:44 pm »
It does not. But it's very easy to check. One day you may have the same question about an unknown PT.
Connect one ohm meter probe to a green wire. Touch the other probe to the PT shell. Should read infinity (OL, etc). Now touch the red/yellow HT center tap. Shouls also read infinity.
Offline scstill
  • https://stillampd.com
    • Still Amp'd
« Reply #6 on: February 11, 2024, 02:28:50 pm »
BTW - I've used similar to this PT before. Might be obvious but if your wall is 120v and you use the gray Primary (117v) you should get a little more volts out. And less out if you use the black primary. 100ohm artificial CT on green wires worked for me.
