September 14, 2026, 06:50:23 pm
Hoffman Amps Forum image Author Topic: Does an arrangement of PS like this give galvanic isolation to the circuit ?  (Read 4608 times)
To me seems that as the heater of the rectifier is feed via a galvanic insulated winding the circuit result to be galvanically isolated but only partially because if plate and cathode of the rectifier shorts the circuit will be directly connected to the line
(so I think this configuration is unsafe)
Your opinion ?
p.s.: Obviously if not preceded by an insolation transformer ad suggested on the schematic
« Last Edit: December 25, 2023, 05:23:24 am by kagliostro »
The circuit is ALWAYS connected to the line! The only danger from a shorted rectifier is to the filter caps.
Thanks Steve
That drawing is incomplete. Electricity comes off the power line, through the rectifier, to filter caps and to tubes, and then.... where?? A ground symbol? But we know the power company gets ALL their electrons back. So we must assume the ground symbols *also* return to the power company. They usually do, for general safety against lightning and leaks.
However "isolé du réseau" means "isolated site". If that is true, the electrons never come back. It won't work at all.
It means insulated from line, I suppose using an insulation transformer and this doubles doubts about that PS
