September 17, 2026, 12:55:42 am
Hoffman Amps Forum image Author Topic: Is it a dual rectifier AC30 head clone? no schematics, newbie 2nd repair project  (Read 6912 times)
Offline fkitch
Merry Christmas everybody,
Ok, after successfully (thanks to you of course!) completing my first tube amp repair I am now onto a new project.
It's a Spain made, early 60s most probably, 8 tube 'Contrafon 750'  head . No info available at all online but I was told by the owner it may be a AC30 clone?
Has 4xEL84 power amp, 2xECC83 preamp, 2xEZ81 rectifiers
Would be possible to ascertain from the pictures if a particular model could have 'inspired' this one please? I have no experience on VOX amps at all, but can't seem to find AC30s dual rectified.
Briefly powered it up, there's strong hum and sporadic frying pan noise. Very dark sound, I used an 8ohm speaker.
thanks!
Offline chocopower
Hi
I have the same amp. Mine is in worst shape even...
Is a pending project, but i found this schematic time ago.
David
Offline Dave
If I were to guess, I'd say it looks like a PA. Some might think that PA stands for Public Address while others might say it stands for Power Amp (Like for an organ preamp or something like that). Whatever, it looks like it could be either.
It has two rectifiers because the manufacturer decided for whatever reason, that it wanted to use 6.3 volt filament rectifiers and EZ81 was common and cheap. But providing enough power to run 4XEL84 was a bit much for just one.
Edit - At another glance, the amp you have and the schematic provided by Chocopower are not the same amp. On the schematic I see one 12AU7 and on your amp, I see two 12AX7
Dave
« Last Edit: December 29, 2023, 02:51:06 pm by Dave »
Main filter caps, then clean the sockets and change tubes.
Since it surely worked in 1959, and parts values are readable, you don't urgently need a schematic just to get it playable again. Just fix what's broken, rotted, or tarnished.
Amplificador Valvulas Años 50(Contrafón)
https://es.wallapop.com/item/amplificador-valvulas-anos-50-contrafon-478114903
He likes it a lot, but he should, since he is asking 500 Euros. Not the same product, but same brand and probably same factory.
Somewhere I saw a date of 1966, which with those rectifiers and history of Spain makes more sense than the "1959" I spouted above.
« Last Edit: December 29, 2023, 03:27:05 pm by PRR »
Offline chocopower
Its a bass amp, or as the name says, contrabass.
Mine  came with a matching 2x15 cab and 2  12au7.
The "schematic" i post is one i found in the web.
Is just the  preamp
David
Offline chocopower
* i din't vandalized the cab..
David
Offline chocopower
JOBESONIK is the brand
Joaquin benavent sonic
David
Offline fkitch
Wow! Yes looks like a bass cabinet
 Would you happen to have a picture of the interior of the amplifier? To compare components with mine…
Offline fkitch
 I think it’s a version of this, with just one channel with one input and  two tone controls instead of one
I will start with filter caps and tubes and let’s see, need to investigate tone stack potential mods to make it more guitar friendly.
Thank you all for your help and inputs, much appreciated!
Offline chocopower
I'll do. Just need some days..
David
Offline AlNewman
You could try reducing the .15 coupling caps to the output tubes.  .1, .068, .047, .022.  ...?
