August 06, 2026, 02:46:50 pm
Hoffman Amps Forum image Author Topic: Re-capping a Fender Studio bass  (Read 6062 times)
Offline pbman1953
« on: January 08, 2024, 11:21:31 am »
HI All,
Happy New Year!
My next venture would to re-cap a Fender Studio Bass. Here's a link to the proposed company that sells kits for the amp-
https://www.amprepairparts.com/fendercapkits.htm
Look for the Part #FCK-19
This kit is for a Super Twin which is similar but not exact. I think that I'd have to use a radial-  750uf/ 3v. Axial's are tough to find in a small voltage
I was wondering if any other parts needed a tweak, value wise. Plus, if you would stay, with the shown 1.5 k grid resistors , or change that value.
Thanks!
« Last Edit: January 10, 2024, 09:40:23 am by pbman1953 »
Offline Latole
Re: Re-capping a Fender Studio bass
« Reply #1 on: January 08, 2024, 12:44:11 pm »
No need to replace 1,5 k grid resistors . Why ?
Read 470 ohms grid resistor and replace if needed.
Check fuse to be sure it is the right one. Too many people put more powerful fuse over years .
Amp need 6 1/4 normal/ fast blow fuse.
All you need are main and bias power supply  filter caps . Forget other caps or resitors. Values are not for this amp and amp may not need them.
You can buy from many store like Tube Depot, Antique electronics
From amprepairparts ; look here; https://www.amprepairparts.com/caps.htm#ftcap
3 F&T 22uF-500V (Main Filters - Decoupling)
2 F&T 220uF-300V (Main Filters)
2 F&T 100uF-100V (Bias Filters)
« Last Edit: January 08, 2024, 12:52:25 pm by Latole »
Offline pbman1953
« Reply #2 on: January 08, 2024, 12:50:52 pm »
Perfect, thank you!
Offline Latole
« Reply #3 on: January 08, 2024, 02:08:54 pm »
You know you must  put positive + side of the bias filter cap to ground.
Offline pbman1953
« Reply #4 on: January 08, 2024, 02:11:35 pm »
yes,thanks!
Offline WimWalther
« Reply #5 on: January 10, 2024, 12:55:09 am »
750uf/ 3v. Axial's ae tough to find in a small voltage.
But really, you can use about any cap that fits,  from 3V to.. maybe 50V?
Offline d95err
« Reply #6 on: January 10, 2024, 02:17:02 am »
In addition to this, 750uF is a very unusual value. Anything from 470 to 1000 uF should be fine.
Offline Latole
« Reply #7 on: January 10, 2024, 03:33:37 am »
HI All,
MouserElectronic have many in axial from 8 to 100volts
Or Digikey ?
https://www.mouser.ca/c/passive-components/capacitors/aluminum-electrolytic-capacitors/?capacitance=750%20uF
One of them;
Offline pbman1953
« Reply #8 on: January 10, 2024, 07:31:51 am »
Thanks guys, I saw the radial at Mouser.
Thanks!
