September 08, 2026, 03:50:38 pm
Hoffman Amps Forum image Author Topic: 6l6 vs el34      (Read 5795 times)
Offline Geezer
6l6 vs el34
« on: June 18, 2005, 05:56:11 am »
        > 6l6 vs el34
<< Prev Topic | Next Topic >>
Author  Comment
ernie jr
Junior tube assistant
(3/31/04 3:23 pm)
 6l6 vs el34
 other than the slight pin out difference, can and amp running el84s with about 450-470 on the plates use 6l6's instead?
if so, any other changes need to be made?
thanks for you help
ernie
ganzonimx
Hey get your own solder
(3/31/04 5:48 pm)
 Re: 6l6 vs el34
 You'r talking about swaping from EL34 to 6L6, right?
rebias the amp, eventualy change the screen resitors to 450 ohm...
Cris
LooseChange
Senior tube assistant
(3/31/04 7:52 pm)
 Re: 6l6 vs el34
 Cris,
This is the first time I've heard anybody say change those screen resistors to 470ohms when switching from EL34's to 6L6's. I figure the 1K resistors are fine. Why do you suggest this??
ganzonimx
(3/31/04 8:09 pm)
 Re: 6l6 vs el34
 I just imagined that you would have changed them  , I have no good reason to do it.
Probably it's not necessary. As the screen current is so low in a 6L6, there would not be a voltage drop that affects the functioning of the tubes.
Cris
LooseChange
(3/31/04 10:05 pm)
 Re: 6l6 vs el34
 Thanks. I've been trying to understand the screen resistor value "thing". So the EL34's draw more current and that is why the 1k is used???
6G6
(4/1/04 8:19 am)
 Re: 6l6 vs el34
 EL 34s draw more heater current than 6L6s.
That's fine if you are swapping from El 34s to 6L6s, but not so good if you are going the other way.
ernie jr
(4/1/04 1:15 pm)
 6550 vs el34
 how about using 6550's in place of el34's
any one have a preference on sound for a
bass amp, b+ about 450-470.
i have bought a used sunn amp, old spectrum I
with el34's, i have extra 6l6's and 6550's.
trying to decide which to use.
thanks for the ideas
ernie
 Topic Commands
Powered By ezboard® Ver. 7.32
