September 08, 2026, 10:00:47 pm
Hoffman Amps Forum image Author Topic: New Oscilloscope - Looking for advice  (Read 9195 times)
Offline Jonas
« on: January 12, 2024, 08:52:51 am »
at least new to me.... I have a B&K Precision model 1474 scope. I plan to use it primarily with tube amps.
I have 0 experience with scopes, but I plan to start by reading the manual / on-line videos
Is this a good scope to start with (assuming it works)?
I'm also looking for replacement probe suggestions
Thanks!!!!
Offline WimWalther
Re: New Oscilloscope - Looking for advice
« Reply #1 on: January 12, 2024, 09:18:21 am »
That scope is perfectly fine for about any audio use, and more.
As for probes, pick up a set of the very inexpensive 60 or 100MHz 10:1 (switchable) probes that can be found on ebay for around $20 or less. I have several sets and they work just fine. And they're cheap enough that you won't stress out if you accidentally wreck them.
Definitely RTFM and watch some o-scope 101 vids on YT.
And one caveat to always bear in mind.. you see all of those controls on that scope? Well, think of them as Data Adjustment Knobs.. meaning that you will always tend to set them wherever they give you what you think you should see - rather than what you might really need to see.
« Last Edit: January 12, 2024, 09:21:03 am by WimWalther »
Offline Lectroid
« Reply #2 on: January 12, 2024, 09:29:19 am »
This is a good tip to remember.
Magis bos clocca!
Free Beer Tomorrow!
« Reply #3 on: January 12, 2024, 10:22:57 am »
Honor the input voltage limitations. (See service manual page 3)
Max. Input Voltage
300 VDC + AC peak or 600 V p-p.
Offline TitaniumValhalla
« Reply #4 on: January 12, 2024, 01:53:56 pm »
This is a good introductory video on how to use your scope to look at an amp:
Offline WimWalther
« Reply #5 on: January 12, 2024, 02:00:37 pm »
Here's another excellent beginner's video, this one is oriented towards analog scopes like the OP's B&K.
i=UX_7-R0uJImTLdYt
Offline joesatch
  • save me from myself.
« Reply #6 on: January 12, 2024, 03:04:45 pm »
i bought this scope over a year ago. i still cant figure out how to use it.  Buy simple!
https://www.amazon.com/gp/product/B01J1MQC3G/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
« Reply #7 on: January 12, 2024, 03:53:53 pm »
PDF files of old books:
http://tubebooks.org/Books/Sicuranza_cathode.pdf
http://tubebooks.org/Books/smith_oscilloscope.pdf
http://tubebooks.org/Books/haas_oscope.pdf
http://tubebooks.org/Books/Middleton_troubleshooting.pdf
http://tubebooks.org has a self-signed security certificate. This is perfectly safe for you, but your browser doesn't know what you are doing and you may have to beat it into loading the site.
Offline WimWalther
« Reply #8 on: January 12, 2024, 06:23:27 pm »
With computer-based scopes, the number of features can be staggering. How much software can you cram into it?
The OP's scope is about as basic as they come. But it's still totally suitable for all sorts of jobs. I think that I owned one of those units, many years ago - though mine was cosmetically different.
Offline Jonas
« Reply #9 on: January 13, 2024, 11:05:50 am »
Thanks everyone, I will get some probes ordered up and do some reading / watching.
Offline WimWalther
« Reply #10 on: January 14, 2024, 01:25:43 pm »
Here you go, check out ebay item 314549314579
These are the same probes I use, and they are perfectly adequate for your purposes. $12.99 shipped per pair.
Offline tdvt
« Reply #11 on: January 19, 2024, 06:39:20 am »
It must be scope month.
A friend who is parsing out unused electronic projects, parts, etc. dropped off a box that included a Tektronix TDS 210, with a dead backlight, salvaged from his work.
Apparently they used a fluorescent tube which seems to wear out in most of them. New tubes seem to be readily available, but lots of home-brew LED conversion mods online as well.
Like the OP, I have zero scope experience, so I will have to start with the videos linked above.
Offline Jonas
« Reply #12 on: January 19, 2024, 09:04:05 am »
THANKS AGAIN! I hope to have time this weekend to start my education. I have the test leads ordered thanks WimWalther!
Offline Jonas
« Reply #13 on: February 06, 2024, 10:36:16 pm »
quick update -
@WimWalther - I purchased those probes and they work well - thank you!!
started out small here but successfully used the scope to determine inner and outer foil on a few caps. I experimented with the noisy white mallorys then moved up to caps that will actually go in the amp.
