August 06, 2026, 03:44:02 pm
Hoffman Amps Forum image Author Topic: Frequency Response Variations with Bias Cap Size  (Read 4546 times)
Offline clyde
« on: January 20, 2024, 04:46:45 pm »
I've read that bias cap size on fixed bias circuits affects frequency response, ie larger uf = lower frequency response.  This was new to me and can anyone confirm the process by which this occurs?
Re: Frequency Response Variations with Bias Cap Size
« Reply #1 on: January 20, 2024, 04:59:15 pm »
I've read green eggs and ham at least 500 times. Still don't believe it!    :icon_biggrin:
« Reply #2 on: January 20, 2024, 05:06:32 pm »
Push pull or single-ended?
Competent designer or an idiot?
Offline clyde
« Reply #3 on: January 20, 2024, 08:06:40 pm »
On another board, new poster.
Offline WimWalther
« Reply #4 on: January 20, 2024, 08:51:32 pm »
If you consider the fact that a typical bias supply is isolated from the grids of the power tubes (and the driver circuit..) by 220-330K per tube, any effects related to bias supply capacity / impedance are kind of out the door.
ETA: This claim also has implications for bias regulators** which can be modeled as true voltage sources or huge caps.
(** which no one should use anyway, unless B+ is fully reg'd..)
« Last Edit: January 20, 2024, 08:57:53 pm by WimWalther »
