September 17, 2026, 01:10:02 pm
Hoffman Amps Forum image Author Topic: Hoffman 18 Watt Stout TMB  (Read 21263 times)
Offline GarlandKelley
« on: January 24, 2024, 01:43:26 am »
Hey everyone,
     I have been building a Hofffman 18 Watt Stout TMB into an old Philco radio. I thought I was finished today but when I plugged everything in, there was no input signal. The lamp turns on and all the tubes are glowing. I get a hum, sometimes a slight oscillation when adjusting the pots but no signal from the guitar input.
     Let me preface by saying that I have scoured the schematics and checked my work many times. The output transformer, input transformer, choke, and tube sockets are all new. I know all the tubes are in good working order.
     I completely understand that this could very likely be a bad solder joint or some other error on my end but I was hoping someone could offer some advice or point me in the right direction as to what the issue could be and how to remedy it. Am I correct in seeing that pins 3 and 8 of V2 are bussed together being connecting to the 820 ohm resistor?
     Thank you for your help, I am a noob and everything is appreciated.
Garland
https://el34world.com/Hoffman/files/Hoffman_Stout.pdf
Re: Hoffman 18 Watt Stout TMB
« Reply #1 on: January 24, 2024, 01:47:49 am »
Here’s a photo of the board and wiring, apologies for the mess.
« Reply #2 on: January 24, 2024, 06:57:33 am »
This is how you can find wiring mistakes
https://el34world.com/Forum/index.php?topic=17701.0
Offline JPK
« Reply #3 on: January 24, 2024, 07:51:02 am »
In addition to the above, take your iron and re-flow all your solder joints (especially all the jumpering that's down low on the turrets). Some look kind of chunky, they should look shiny and smooth. I like to use a magnifying glass to examine all my solder joints. You'd be surprised what you see. When I build amps I test it in steps. Like Heaters first. Then B+. Etc. Waiting till the end to test everything makes it harder to troubleshoot. Did you check all your the voltage points against what is expected on a working amp?
« Last Edit: January 24, 2024, 08:01:04 am by JPK »
I love tubes
« Reply #4 on: January 24, 2024, 08:53:40 am »
That's correct, but I don't think the resistor on the board is 820Ω. Looks like a 2.2K to me.
The dangling 82K feedback resistor is in danger of shorting to the B+ dropping resistor. Needs some insulation.
Your layout really sucks. May be the worst I've ever seen. Sorry. Had to be said.
« Reply #5 on: January 24, 2024, 11:33:07 am »
I normally use Kester 83-4000-0000 SN60PB40 solder but it is unavailable so I had to use Kester 83-7068-1402 and it just does not flow like the other stuff and looks dull when dried no matter how carefully I solder. I am new to amp building as previously stated so how would I test voltage points?
Sluckey, while I want to say I appreciate your advice, your comment about the layout serves no purpose and in no way is helpful. What about it sucks? I followed the board layout provided and the wire routing was restricted due to using a donor radio chassis. The components barely fit on the board and have to be where they are in order to fit the chassis. I specifically stated that I am a noob to avoid snarky comments like yours but being the internet there is ALWAYS someone who has to state some sarcastic, unhelpful information. To clarify for you, that in no way “needs to be said”.
« Reply #6 on: January 24, 2024, 11:53:29 am »
When you have bare wires crossing like that in the pic above always use heat shrink (insulation)  on the leads to prevent any short that could possibly happen.
If that Kester solder you used is lead free then you ain't going to like it.  Always use the right stuff even if you have to wait for it.
Sluckey was just being honest.  And what he said is true.  What you did was take a layout that was meant for a clean chassis and try to adapt it to the old chassis and the result is really a rats nest of wiring. What he is alluding to is that it would be much better to have adjusted the layout, redraw it if necessary to adapt to the components being in different positions. We all know you are a beginner. I just installed one of these into a Vox AC15CC1 chassis and had to flip the whole layout vertically to make it work because everything was backwards from that layout. So I redrew the layout to work.
Sluckey is extremely knowlegeable and helpful so getting upset with him isn't goin to work very well for you. Just unwind yourself relax and the help will come.
now  how about that 820 ohm resistor he pointed out?
« Last Edit: January 24, 2024, 12:05:50 pm by mresistor »
« Reply #7 on: January 24, 2024, 12:08:57 pm »
I'm sorry you took it that way, but it serves a purpose. There was nothing snarky about my remark. It was straightforward and to the point. It's a prime example of what not to do when building an amp. There's nothing wrong with the board. It's everything else that sucks. Things like putting the sensitive input jack right over the rectifier tube is crazy. Very long wires crisscrossing the chassis is another example. You have broken dozens of "things not to do" rules. It's like you have never seen the insides of an amp. I'm sure you will find that your layout is a major contributor to the problems that amp has.
Sometimes criticism is positive and sometimes it's not. But you can learn from both. I did not make that statement in a mean spirited way, but I did want to shock you into realizing just how big a mess you have made. I try to speak the truth but I'm also very plain spoken. I wish you luck but I'm not optimistic about the helter-skelter way you crammed that stuff into that Philco chassis.
I did point out a wrong value resistor you put on the board and pointed out a danger. Maybe you'll find that helpful.
« Reply #8 on: January 24, 2024, 02:32:37 pm »
Apologies for being so hot. I’m frustrated because this has been a huge project with many labor hours including restoring the cabinet. I appreciate the explanation as to why the poor layout is more than just an aesthetic issue and could be the root or one of the main causes of the problem. I do respect the expertise of the users of this forum and appreciate the advice. That resistor is indeed a 2.2k so I must not have received an 820 ohm resistor in my BOM. Still a major mistake on my part as well as the other issues. Is this enough of an issue that it could be the primary issue? Thanks again.
« Reply #9 on: January 24, 2024, 02:39:43 pm »
This is a video explaining my reasoning for the layout decisions. I am not sure how I could modify this and the board barely fits in the space on the underside as is.
« Reply #10 on: January 24, 2024, 03:27:51 pm »
That resistor is indeed a 2.2k... Is this enough of an issue that it could be the primary issue?
It has nothing to do with the issues I heard in your first video, but it does need to be replaced with the correct value. The only reason I noticed it was because you asked, "Am I correct in seeing that pins 3 and 8 of V2 are bussed together being connecting to the 820 ohm resistor?" So, I looked and saw the resistor was the wrong value.
I think your best approach to troubleshooting is to follow the link posted by EL34. Once any wiring errors and/or wrong component values are sorted, the amp should pass a guitar signal. But I'm almost certain it will sound very noisy and generally crappy.
I get it that you want to keep the old looks of the radio. And that can be done and still have a good looking amp that works. But it could be a major rework. Several of the forum members (including myself) have converted old radios to amps. They don't have to necessarily look good but they need to follow some basic building rules. I already have some ideas for your project that will allow you to keep the front of the radio looking original and also house your amp. Looks like you will be accesing the amp from the back side of the radio cab so that makes it even easier.
But follow the link posted by EL34 first. If no joy, I'll share my ideas with you. BTW, I just drug this '46 Philco cab to the curb last week. Gone by the end of the day.    :icon_biggrin:
« Reply #11 on: January 24, 2024, 03:36:26 pm »
 :laugh:
at an estate sale 15 years back picked up a '39, tore it down, finished, new speaker, drove it 300 miles, gave it way.  The story from the estate, "was Dad's last project, he requested it ONLY be gifted to someone that "knew what it was""  made my contributions to his project, gave the same "instructions on gifting" and set it free again
Offline JPK
« Reply #12 on: January 24, 2024, 03:39:22 pm »
Sometimes the project documents have schematic or layout that shows "typical" voltages. Sometimes you can get them from another person who built one. I haven't built one of these so I don't have one myself.
I love tubes
« Reply #13 on: January 24, 2024, 10:44:50 pm »
Did you ever get that 5F1 Champ working?
Offline AlNewman
« Reply #14 on: January 24, 2024, 10:52:06 pm »
Hate to say it, but it's too bad you just didn't rebuild the radio.  You already restored the cab.
« Reply #15 on: January 25, 2024, 12:55:13 am »
Sluckey,
Thank you for your help with this build and the 5F1 Champ build. I did end up getting it working and it sounds great! I’m hell bent on getting this one operational. These builds are used for recording in my home studio. I trust your expertise on this but want to see if I can get it operational before completely rebuilding. I included a video of that Champ on here.
AlNewman,
I know I’ve kind of violated the credo of antique restoration and antique radio aficionados. I got this radio for free and would not use an am/fm radio. I enjoy the process of restoring the radio cabinets and building an amp into them. I also love the aesthetic of these old Philcos in particular and like having a wide palette of amps to use for recording.
« Reply #16 on: January 25, 2024, 11:19:18 pm »
Okay, I checked everything by printing out black and white board layouts and tracing/highlighting every path and component. I checked the values of every board component as well. I also reflowed solder joints. I am still not getting any input audio. The bad oscillations from the pots are gone but there is still a small amount of noise coming from the volume pot. Do you have any advice? The lamp is operating properly and all of the tubes are glowing without red-plating. I’m definitely getting internal audio to the speaker. The noise floor of the amp is low but I can hear the subtle crackle of life and get that noise when adjusting the volume pot.
« Reply #17 on: January 26, 2024, 12:34:51 am »
You missed something. Do it again.
Also check voltages at every filter cap and all pins on all tube sockets. Post your voltages.
« Reply #18 on: January 26, 2024, 12:53:37 am »
Do you mean retrace everything again as well as reflow solder joints or just reflow all solder joints again? This is embarrassing but how do I check voltages at those locations? I’m assuming the amp should be off, unplugged, caps drained, with no tubes when I check voltage? Thanks for helping me figure this out. Also, is the buss wire supposed to be soldered to the back of all the pots?
« Reply #19 on: January 26, 2024, 05:25:58 am »
typical sound for either bad solder joint, or DC on volume
NO, you don't need to solder the buss wire to the pots.
Offline JPK
« Reply #20 on: January 26, 2024, 07:40:27 am »
No you want it powered on. If you're not comfortable with checking lethal voltages you might want to have a friend or amp tech help. What I do is clamp the negative lead of my multimeter to the metal chassis (or ground buss). Then I keep one hand at my side and only use the other hand to hold the positive probe to test LIVE voltage points. At this point I'd leave the tubes in as you've already had it powered up, and if there is damage to them, too late. I no longer solder the buss to back of pots. I just suspend the long buss wire in the air using soldered jumpers (20 ga bare buss wire) to the pot terminals to support it.
« Last Edit: January 26, 2024, 07:48:59 am by JPK »
I love tubes
Offline johnnyreece
« Reply #21 on: January 26, 2024, 02:53:47 pm »
One thing to remember when probing a live amp:  Some of the places you touch with your probe can make a loud noise in the speaker.  DON'T jump and accidentally short something out.  When I was younger and more timid, I'd often clip my leads to each point with the amp off, then turn it on and let it warm up to measure voltage.
« Reply #22 on: January 26, 2024, 04:09:05 pm »
Okay everyone,
I replaced that resistor and took all the voltage measurements of all tube pins and multicap. I had the speaker connected, all tubes in, powered on. I have attached a chart of all the ac/dc readings and some videos of odd things I noticed from my limited knowledge perspective. I hope I haven’t damaged anything. Any help is appreciated.
« Reply #23 on: January 26, 2024, 04:29:21 pm »
you might be missing the milli in your AC volts
What is point A to ground, VDC measure???
WITH the PA tubes OUT, amp on, what does the plate pin on each tube socket measure to ground VDC
« Reply #24 on: January 26, 2024, 04:41:26 pm »
Zero volts on V1 pin 1 will prevent guitar signal from reaching the speaker.
Offline Bergera
« Reply #25 on: January 26, 2024, 04:52:03 pm »
yeah you seem to be getting power to the second triode in v1 but not the first
so something is a miss a round here, maybe
« Reply #26 on: January 26, 2024, 06:34:12 pm »
Should I be reading voltage at that 500p that connects to pin 1 V1?
« Reply #27 on: January 26, 2024, 06:39:30 pm »
yes
« Reply #28 on: January 26, 2024, 07:21:42 pm »
That may be the issue or one of the main issues. I’m not reading any voltage on either side of that.
« Reply #29 on: January 26, 2024, 07:35:12 pm »
B+ voltage comes from turret A, goes through 100K to turret B which is jumpered to turret C. The red wire on turret C takes the B+ voltage to V1 pin 1. Now you find what is broken in that simple ABC chain.
« Reply #30 on: January 26, 2024, 07:47:49 pm »
That 100k resistor is reading 511 on one side and nothing on the other. Is that just a bad resistor?
« Reply #31 on: January 26, 2024, 07:53:15 pm »
The lead coming from turret A reads 511 but the lead going to turret B reads nothing
« Reply #32 on: January 26, 2024, 08:28:01 pm »
Probably. But it could be a bad solder connection. Or turret B is grounded to the chassis. Use your ohm meter to check if B is grounded.
« Reply #33 on: January 26, 2024, 08:50:57 pm »
What setting would I use and what reading am I looking for?
« Reply #34 on: January 26, 2024, 08:53:02 pm »
Just replace the resistor.
« Reply #35 on: January 26, 2024, 09:00:11 pm »
Turret B was grounded to the chassis, lol. I’m getting signal from the input but something is still definitely wrong. I’ll upload a video. You rock!
« Reply #36 on: January 26, 2024, 09:16:41 pm »
Pin 1 V1 now reads 417 AC. Pin 2 still reads zero but it sounds like I’m picking up AM radio when I touch the probe to the pin. The volume pot affects this radio interference as well. Pin 3 now reads 2V AC. Pin 7 is still 0 but very noisy when I touch the probe to the pin. Sluckey, some of this may be the consequences of my poor layout like you had warned me but I can tell there is still something wrong. I feel like I am so close and greatly appreciate your ongoing advice, everyone.
« Reply #37 on: January 27, 2024, 01:22:37 pm »
Does anyone have an idea of what might be happening in the above video? Also, should pin 2 be receiving any voltage? I’m wondering if pin 2 is related to the noise problems on the volume pot and possibly the overall issues with the overall tone? Does any of this sound like tube issues to you?
« Reply #38 on: January 27, 2024, 02:10:46 pm »
are you trying to go viral?  I go to the tube couple times a year to "find" that magic bolt to take a fender off
since you're there, look up "basic troubleshooting tips for guitar amps" or some such wording
« Reply #39 on: January 27, 2024, 03:40:16 pm »
Pin 1 V1 now reads 417 AC... Pin 2 still reads zero...Pin 3 now reads 2V AC... Pin 7 is still 0...
Pin 1 and pin 3 should be DC, not AC. The voltage on V1 pins 2 and 7 are supposed to be zero. Nothing wrong there.
I suppose there could be some more errors in the amp but the elephant in the room is YOUR LAYOUT! No amount of logical troubleshooting will fix that.
« Reply #40 on: January 28, 2024, 09:15:33 am »
Disconnect the green wire from the feedback resistor. Any joy?
Here's my proposal to fix your layout. Remove all the wiring on the tube side of the chassis. OK to leave the filament wires. Relocate the controls to the right side. Label the tubes as shown. Now rewire the amp. That board was designed for this layout. The board is only part of the total layout. It has to work with the tubes and controls as one layout. The wires will be much shorter and more directly connected between the board, tubes, and controls. No more long crisscrossing wires to act as antennas to pick up all kind of noises and interference.
Assuming there are no more errors on the board, the amp should work fine if you follow my proposal. And it will be much more serviceable. Easier to troubleshoot. I know it's a lot of work but it will be faster than trying to make a working amp out of what you presently have.
Oh yeah, read the manual for your meter and learn how to use it properly.
« Reply #41 on: January 28, 2024, 12:15:57 pm »
Sluckey,
Very much appreciate your advice/guidance/time. That rework is totally doable. I was worried I was going to have to redesign my own turret board. I had considered placing the controls on the side like that but made the decision for the back solely for aesthetic reasons. When I disconnect the green feedback wire, the noise floor of the amp is better until that threshold on the volume pot. The guitar signal is still distorted in the same way that is not proper and once I reach that particular threshold on the volume pot, the noise returns and there is a high frequency squeal that is constant. Do you think performing the rework first is advisable? I would like to pinpoint the problem first but understand that may be or is very likely related to the layout issues.
Garland
« Reply #42 on: January 28, 2024, 12:17:38 pm »
The squeal is only with my guitar volume turned up as well, disappears when volume is down.
« Reply #43 on: January 28, 2024, 12:22:42 pm »
Could this be related to the tip of the input jack with the 33k resistor going to pin 2 of V1?
« Reply #44 on: January 28, 2024, 12:45:25 pm »
Design rework in a nutshell, move input and controls to the side of the chassis next to the tubes and reverse the positions of power tubes and preamp tubes?
« Reply #45 on: January 28, 2024, 12:55:50 pm »
input close to input, PA away from input stuff, yep
« Reply #46 on: January 28, 2024, 01:15:33 pm »
Awesome sauce. Thanks again everyone. I’m doing the rework now and will post the results when I’m done.
« Reply #47 on: January 28, 2024, 04:13:01 pm »
This IS layout. It is just like setting up a vocal system with the mike aimed at the speaker. It is fine but meek at very low gain settings. It howls loud at some higher gain setting.
Amps do this too but the electric  fields can "howl" supersonic. You don't hear the scream but it mucks-up normal sound and throws strange hetrodyne birdies at odd frequencies.
« Reply #48 on: January 28, 2024, 04:44:19 pm »
Okay, changing the layout fixed the nose issue. The tone controls seem to be working properly, the volume pot is working correctly, and the amp is nice and quiet. I damaged the 33k resistor that goes from the top of the input jack to pin 2 of V2 so I currently have a 22k  resistor in its place to test the amp. That resistor may be the problem I’m having but it still doesn’t seem like the amp is sounding the way it should. I get some breakup towards the top of volume range but the overall volume seems low and it doesn’t seem to crunch the way I was expecting this high gain 18 watt amp to breakup. I’ll wait to share a video once I replace the resistor but do you have any idea why I might be having this issue?
« Reply #49 on: January 28, 2024, 05:10:48 pm »
Noise issue*
I should clarify that I don’t have another 33k resistor currently so I substituted the closest value I had for now. I also swapped power tubes and that didn’t change anything. I swear I’m almost done with this build and then I’ll be out of your hair for a long time, lol.
