September 17, 2026, 03:29:25 am
Hoffman Amps Forum image Author Topic: Tube preamp EQ bypass switch  (Read 4534 times)
Offline joedonchev
« on: January 27, 2024, 10:03:54 am »
Hi,
Can I put a switch to bypass the EQ section in the clean channel of my Preavey Rockmaster Preamp?
Here is the EQ portion:
https://drive.google.com/file/d/1gWRBaYpCtHRGhx3QswsNOcl6nc8GumQW/
Re: Tube preamp EQ bypass switch
« Reply #1 on: January 27, 2024, 12:24:21 pm »
Yes. May be easier to just use a SPST switch to open the ground connection though. You get pretty much the same effect.
Offline Bash
  • Tu be or not tu be
« Reply #2 on: January 28, 2024, 01:27:55 pm »
This works very well on my AB lite amp.
It is very simple to do (and remove if you'd want to). Makes the amp a lot louder though.
