September 14, 2026, 10:11:19 am
Hoffman Amps Forum image Author Topic: Representation  (Read 32776 times)
Offline azazello
Representation
« on: February 01, 2024, 09:40:13 am »
Thanks for admitting. My name is Nikola /Bulgarian in Baltimore MD/. I have more 25 years tube skill.
I also use full range speakers Coral and Ellectro Voice - on the last photos /Middle speakers are disconnected, Full range sp. are direct connected to amp, without crossovers, that IMO, press and change the sound/.
Cannot combine your first and second post because of the attachment limitation. You are only allowed 4 attachments per post... sluckey
« Last Edit: February 01, 2024, 12:52:08 pm by sluckey »
Offline azazello
Re: Representation
« Reply #1 on: February 01, 2024, 09:44:51 am »
I also use full range speakers Coral and Ellectro Voice - on the last photos /Middle speakers are disconnected, Full range sp. are direct connected to amp, without crossovers, that IMO, press and change the sound/. On the photo SE 2A3 RCA, SE 300B, SE GK71, SE6S4S
Re: Representation
« Reply #2 on: February 01, 2024, 11:03:17 am »
Is this just you showing your gear or do you need help for repairs?
Offline azazello
Re: Representation
« Reply #3 on: February 01, 2024, 11:24:54 am »
 I have more 90 tube projects and amps. I repaired a lot of tube US brands. Thanks for interest. /All amps are my work/
« Last Edit: February 01, 2024, 11:29:29 am by azazello »
Re: Representation
« Reply #5 on: February 01, 2024, 01:03:07 pm »
Stop reporting this post
I moved you here because you posted in  the tech help forum
You are just showing your gear, so you do not post in the tech help forum
« Last Edit: February 01, 2024, 01:36:45 pm by EL34 »
