September 15, 2026, 12:09:52 am
Hoffman Amps Forum image Author Topic: 1760J OT for Blues Jr.  (Read 4889 times)
Offline roseblood11
    • Layouts and Pictures
« on: February 20, 2024, 06:13:19 pm »
The Fender Blues Jr. has an output transformer with a 7000 ohm primary and a 8 ohm speaker.
As I want to use it as a practice amp for bass, I plan to install a bigger transformer with a 4000 ohm primary and 4, 8 and 16 ohm secondaries. It was used in a Carvin amp with 4*EL84, and I think it's more or less identical to the Hammond 1760J.
Should I connect the 8 ohm speaker to the 4 ohm tap?
« Last Edit: February 20, 2024, 06:42:20 pm by roseblood11 »
Offline Ronquest
Re: 1760J OT for Blues Jr.
« Reply #1 on: February 20, 2024, 07:04:04 pm »
Yes.
Offline WimWalther
« Reply #2 on: February 20, 2024, 09:13:21 pm »
And after you pull the stock OT, you can sell or swap it to some guy who needs an OT for his 30s-40s Zenith console radio! ;-)
Offline roseblood11
« Reply #3 on: February 21, 2024, 01:33:47 pm »
I'll pull a Heyboer OT that will be used in a 5e3 build. The Fender OT is long gone...
