August 30, 2026, 04:20:28 pm
Hoffman Amps Forum image Author Topic: BIAS measurement method - a question  (Read 5134 times)
« on: February 26, 2024, 03:57:46 am »
I would like to know if by using the method of the resistor in series with the anode voltage and two resistors in series with the connection wires of the instrument it is possible to prevent the anode voltage from reaching the front panel or if this solution is not possible to put it in practice
Offline Latole
Re: BIAS measurement method - a question
« Reply #1 on: February 26, 2024, 05:03:44 am »
It would be much simpler to use the tried-and-tested and safe method of putting a 1 ohm resistor ( on red ) on each tube cathode connected to ground .
Resistors you can even leave in place once the bias is over, which will be useful for the next bias.
« Reply #2 on: February 26, 2024, 06:09:53 am »
Current sensing resistors and test points in an output valve anode circuit seems like a recipe for terrible lead dress.
Offline acheld
« Reply #3 on: February 26, 2024, 09:36:29 am »
This would be no more than a gimmick, IMO, but you certainly could place a Hall effect current sensor at your test point,  with the meter in the front panel.
The sensor is not directly "in circuit," and thus does not bring high voltage to the front panel.   Not sure if there are inexpensive (and accurate) ammeters in the milliamp range, but it could be done safely and without screwing up your signal path.
A lot of trouble for not much benefit.
Offline WimWalther
« Reply #4 on: February 26, 2024, 10:10:51 am »
Not sure if there are inexpensive (and accurate) ammeters in the milliamp range (...)
Many ammeters are actually mA or even uA meters, with parallel current shunts added for reading higher ranges.
