September 08, 2026, 02:02:30 pm
Hoffman Amps Forum image Author Topic: dropping heater voltage        (Read 5872 times)
Offline Geezer
« on: June 18, 2005, 05:57:18 am »
        >   dropping heater voltage
<< Prev Topic | Next Topic >>
Author  Comment
ganzonimx
Hey get your own solder
(3/31/04 11:16 am)
 I like to ask to not mess up:
I'm working on a Bass amp with six 6L6 and 3 12A?7 tubes, makes up for a heater current of
6 x 0.9 A 3 x 0.3 A = 6.3 A
The heaters are at 7.3V. I like to reduce the voltage a little.
If I use 0.1 ohm resistor, that would drop the voltage by
0.1 ohm x 6.3 A = 0.63 V
the dissipation would bee 0.63V x 6.3 A = 4 W
Would that be OK to use a 0.1ohm/10W resistor?
Cris
Tiny Daddy
I will work on all amps
(3/31/04 8:58 pm)
 Re: dropping heater voltage
 You could use a resistor, or a diode or two.
6G6
Junior tube assistant
(4/1/04 8:23 am)
 Cris,
Is that 7.3V with the tubes in or without a load?
If it's without a load, the voltage will come down some when you have the tubes in.
ganzonimx
(4/1/04 10:38 am)
 7.3VAC is with tubes in, I have 130VAC from the wall.
I also thought about lowering the voltage from the wall with a 6V ore 12V PT, but as it is a bass amp, I prefere to keep the little higher volatge on the plates.
How should I use the diodes?
Cris
Tiny Daddy
(4/1/04 1:38 pm)
 Since it's AC, put 2 diodes in parallel and then in series with the filaments and they will drop around 0.7 Volts.
Edit: The diodes need to be paralleled but connect the anodes to the other's cathode.
Edited by: Tiny Daddy at: 4/1/04 1:40 pm
ganzonimx
(4/1/04 1:44 pm)
 THX T-Dady, I'll try that later today!
Edit: I used some old diodes I had laying around, they drop 0.9V, now the heaters are 6.3V
Cris
Edited by: ganzonimx at: 4/1/04 6:15 pm
Tiny Daddy
(4/1/04 7:25 pm)
 Make sure the diodes are rated for 6 Amps or more. Each diode is conducting only half of the time so 6 Amps gives some safety margin.
 Topic Commands
Powered By ezboard® Ver. 7.32
