August 30, 2026, 07:39:49 am
Hoffman Amps Forum image Author Topic: Installing a 3 prong wire & plug  (Read 7364 times)
Offline pbman1953
« on: February 29, 2024, 08:51:28 am »
I bought an Acoustic 150B bass amp that has a 2 prong. After I install the 3 prong wire , would I need to disconnect the grounding switch?
Offline Dave
Re: Installing a 3 prong wire & plug
« Reply #1 on: February 29, 2024, 09:12:09 am »
Yes, and the associated capacitor is typically referred to as the "death cap". It should be removed.
Dave
Offline pbman1953
« Reply #2 on: February 29, 2024, 09:15:48 am »
Dave
Would it be enough to snip the one side of the 47k resistor to take it out of the circuit?
Offline WimWalther
« Reply #3 on: February 29, 2024, 11:29:10 am »
You mean R401, the 4K7 resistor in series with the neon? No, you need that, assuming the neon is your pilot lamp.
Just remove C403.
Offline pbman1953
« Reply #4 on: February 29, 2024, 11:32:14 am »
You mean the 4K7 resistor in series with the neon? No, you need that, assuming the neon is your pilot lamp.
Just remove C403.
You're right, saw that. I cut the wire leading to the cap
Offline pbman1953
« Reply #5 on: February 29, 2024, 11:42:24 am »
Next question, I think there's a bit of 60 cycle hum, would a new filter cap solve that?  There's 1- 3200 uf/ 75v computer grade cap
I sent a schematic of the power section.
Which other electrolytics would be best to change?
« Last Edit: February 29, 2024, 11:47:48 am by pbman1953 »
Offline WimWalther
« Reply #6 on: February 29, 2024, 12:00:51 pm »
No idea. Depends what's causing the hum, eh?
Sorry, not seeing it. What's the p/n?
The bad ones? ;-)
In most cases, the first cap after the rectifier takes the most abuse. If you're all about replacing caps, start with that one and go from there.
Offline WimWalther
« Reply #7 on: February 29, 2024, 12:03:27 pm »
Btw, you don't necessarily need to remove / disable a grounding switch when installing a 3-wire cord.
The Peavey KB300 came from the factory with a 3-wire and a grounding switch. See attached.
Offline Soulfetish
« Reply #8 on: February 29, 2024, 12:26:19 pm »
Any capacitor from AC line to chassis needs to be a safety "Y class" rated capacitor. These are specially rated and tested capacitors designed for this purpose.
If someone is updating a 2-wire AC input, they need to cut the original capacitor out. This cap has a real risk of failure. I've seen them fail, even when used at 120V mains.
Offline pbman1953
« Reply #9 on: February 29, 2024, 01:00:45 pm »
I'm going to do them all. Due to the age , why not
Thanks for the help!
Offline WimWalther
« Reply #11 on: February 29, 2024, 08:58:32 pm »
Simple rules..
Think of an "X" type cap as a "cross", as it goes 'across' (between) the AC live & neutral lines.
Think of the "Y" type as a "wye" connection, as in one cap each from line & neutral to AC ground.
