September 08, 2026, 12:17:58 pm
Hoffman Amps Forum image Author Topic: Bad Cat minicat Sampson Era  (Read 22255 times)
Offline Paulus01
« on: March 12, 2024, 01:35:08 pm »
Hello. I trying build this amp last 2 month. But something I doing wrong. I found just one mistake heaters resistors must be 220 Ohm. And i using power transformer hammond 290 wex. Are somebody build this thing?
Re: Bad Cat minicat Sampson Era
« Reply #1 on: March 12, 2024, 01:51:56 pm »
We can help even though we may have never seen or built this amp. But you have to provide more info. I see one error on the schematic that will prevent this amp from working properly, so if you built according to this schematic your amp cannot work properly.
Offline Paulus01
« Reply #2 on: March 12, 2024, 03:22:22 pm »
12ax7: On the first pin 237 v, 6 pin 160 v. Voltage after bridge 285 v. Master volume not work. And am not using pair 220 Ohm resistors on the heaters. Thanks for help! On the photos others amps not my.
« Reply #3 on: March 12, 2024, 06:28:40 pm »
The error I'm referring to is...
Look at the schematic. The right side of the master pot ***MUST*** be grounded for the amp to work.
Offline Paulus01
« Reply #4 on: April 06, 2024, 10:17:17 am »
Report!
And finally Amp work. But! If insert cabinet, amp have 50-60 Hz hum, if using as preamp and insert (as amp) in reactive load box, it is noiseless. This is little beast can all from clean sound to dirty (if using pedals). Line out not working with 10 ohm 10 watt resistor, and I changed to 8 ohm.
Thanks for past  advice!
Offline Paulus01
« Reply #5 on: May 01, 2024, 04:32:45 am »
Hello. I would like have mid range control! For example 370 Hz, -6 dB. Do you have  ideas?
Offline darkbluemurder
« Reply #6 on: April 09, 2025, 03:43:11 am »
I recommend the Chieftain midrange control as I found that it works very well and has little insertion loss. Experiment with the pot value - start with 250k as in the original and adjust lower or higher depending on what you want.
Cheers Stephan
