August 29, 2026, 09:10:06 pm
Hoffman Amps Forum image Author Topic: Tweed 5E3: ghost oscillation behind notes  (Read 4905 times)
Offline Lambertini
  • Learning tube amps
« on: March 14, 2024, 02:43:19 pm »
Hello!
Working on my new 5E3 build, I'm facing a new issue: some weird oscillations (like old modems...) appears after few minutes of heating, a while after some uggly ghost oscillations came after each bass notes.
Any idea where does that can come from?
Sound clip
« Last Edit: March 14, 2024, 06:09:11 pm by Lambertini »
Offline Dave
Re: Tweed 5E3: ghost oscillation behind notes
« Reply #1 on: March 14, 2024, 02:48:06 pm »
I have read a lot about "Ghost" notes because I have encountered them to a super annoying degree on one amp. The consensus seems to be inadequate power supply filtering, but my experience with them was unsolvable. At least, unsolvable by me. Good luck.
Dave
Offline Lambertini
« Reply #2 on: March 14, 2024, 04:28:23 pm »
Thank you Dave. I don't think so, I've upgraded the 1st filter cap to 30 µF, with absolutely no effect on this. Could be a bad tube but I haven't 6V6 and 12AY7 spare yet. On their way.
I suppose I would have to track them with a scope...
Offline Dave
« Reply #3 on: March 14, 2024, 04:31:16 pm »
Yeah, I found mine on a scope. Still never solved it though.
Dave
Offline Lambertini
« Reply #4 on: March 14, 2024, 06:03:31 pm »
Where did you locate the source?
Offline Dave
« Reply #5 on: March 14, 2024, 06:33:56 pm »
Mine was a different amp, but I found it at the second gain stage plate/output. Never found any solution. If that gain stage was in play, it ghosted.
Dave
Offline Lambertini
« Reply #6 on: March 14, 2024, 07:29:24 pm »
Mine seems to be generated, or at least sustained, after V1/V2 (preamp/PI). With preamp tubes installed, once the "old modem noise" starts, chanel volumes have no effect. Tests with V1 and V2 removed on-going.
