September 08, 2026, 04:24:49 pm
Hoffman Amps Forum image Author Topic: Oscilloscopes on a budget  (Read 14504 times)
« on: March 28, 2024, 08:51:54 am »
Check out this video
This technician test a $18 oscilloscope and uses it to fix a commodore computer.
They are now $21 and there is a $24 version that has better cable/probes.
https://www.aliexpress.us/item/3256805458469353.html
There are more expensive units also at Ali.
I buy stuff from Ali Express all the time in case you are concerned about this site.
Offline Latole
Re: Oscilloscopes on a budget
« Reply #1 on: April 25, 2024, 02:42:20 pm »
Nice scope, can I test 240 volts sine wave or it is only good for low voltages ?
« Reply #2 on: April 25, 2024, 02:45:37 pm »
I don't remember
Did he say in the video?
Offline Latole
« Reply #3 on: April 25, 2024, 02:59:52 pm »
I don't know. I did not listen all.
« Reply #4 on: April 25, 2024, 03:28:42 pm »
from what I seen, he stays mostly on the digital side of things, signal path stuff.
from what I know about scopes, you can measure about any VAC or VDC with "input conditioning" so things like voltage dividers for DC and step-down transformers for AC.
scopes aren't really the go-to piece of equipment for "power"  that's best done with meters designed for that purpose
Offline acheld
« Reply #5 on: April 25, 2024, 06:22:39 pm »
I got one after seeing the price and part of the video.
It is a very simple device, BUT it seems to work very well.   Locks on to signal readily, and displays nicely.
Product info states:   1X 400VPP 10X 800VPP
I would not consider this as a replacement for a standard 'scope due to its simplicity . . .
But I will use it as a monitoring device.   And if it craps out, well ok,  I'm out $24.
Offline Latole
« Reply #6 on: April 26, 2024, 03:05:01 am »
Thank you all.
Last Week I just bough Hitachi V-422, second hand, for $90 us
Complete with manual an 2 probes. It work well
« Reply #7 on: April 26, 2024, 07:20:47 am »
That explains that
Offline Latole
« Reply #8 on: April 26, 2024, 07:28:01 am »
