September 15, 2026, 03:25:22 pm
Hoffman Amps Forum image Author Topic: Standby disconnecting G2 from PS (and connecting it to negative Bias Voltage)  (Read 4167 times)
I'm sure I asked about this way to perform a Standby here on the forum but I'm not able to remember the answer I received
Which are the advantages and disadvantages on using this kind of Standby ?
Why not only disconnect G2 from the PS but also connect it to the negative Bias voltage ?
In a Cathode Bias amp may G2 be connected to ground instead to a negative voltage ?
« Last Edit: April 23, 2024, 03:42:25 pm by kagliostro »
Whell, I've find the old thread (2014)
https://el34world.com/Forum/index.php?topic=17689.msg178461#msg178461
the answer, from our friend Darryl was:
...... It would ensure the output valves were completely cut off in standby.
p.s.: Reading the old thread you'll find also explanation about the reason for the relay presence
