September 16, 2026, 09:20:23 pm
Hoffman Amps Forum image Author Topic: 2-el84 cathode biased amp.  (Read 4554 times)
Offline MarkT
« on: April 30, 2024, 01:06:36 am »
1 of the tubes is red-plating slightly. Can be seen with the room lights off.
I switched the tubes around and the red-plate occurs on only the one socket.
I'm thinking its a dirty/oxidy/loose socket or the 110 ohm grid resistor going bad. I'm going to clean the socket with a contact clean. Let it dry real good and go from there.
Cheers.
MarkT
If you don't play it, it turns to dust.
Offline dtcurare
Re: 2-el84 cathode biased amp.
« Reply #1 on: May 08, 2024, 10:16:15 am »
I may have that on a new 18 tmb build.  Its V5 on mine.
Offline AmberB
« Reply #2 on: May 08, 2024, 01:07:21 pm »
My suggestion would be to use a common cathode resistor for both EL-84s.  That way, you know that you have a specific resistance for both tubes.
Offline passaloutre
« Reply #3 on: May 08, 2024, 02:05:24 pm »
What’s the measured dissipation?
« Reply #4 on: May 08, 2024, 02:51:50 pm »
Did you mean to say "use a separate cathode resistor for each EL84?
