September 17, 2026, 03:23:33 am
Hoffman Amps Forum image Author Topic: Single Ended Spitfire  (Read 3753 times)
Offline jjschessmaster
« on: May 02, 2024, 08:19:44 am »
Looking at purchasing a single ended amp that runs a 5e2 princeton preamp into the power amp.  I'm looking at modding the amp to use a matchless spitfire preamp (parallel triodes) vs the cascade of the princeton.  Question is ultimately the spitfire is a push pull amp with a phase inverter.  Is there a "significant" impact of omitting phase inverter circuitry by splicing the spitfire preamp onto a single ended power amp?  I know its all subjective, but curious if there are any gurus that have tried this or see a glaring "don't even try, without replicating PI".  My real concern is gain difference between parallel and cascaded triodes wouldn't give enough juice to the power amp.
« Last Edit: May 02, 2024, 08:43:16 am by jjschessmaster »
Re: Single Ended Spitfire
« Reply #1 on: May 02, 2024, 08:52:25 am »
You don't have to replicate the PI but you will need another gain stage. Otherwise, your amp will likely be very quiet and lifeless.
