September 16, 2026, 11:39:13 pm
Hoffman Amps Forum image Author Topic: 100 hz noise Selmer Treble N'Bass Mk2  (Read 3796 times)
Offline Nikolaj2121
« on: May 04, 2024, 03:25:33 pm »
Hello everyone
I have this Selmer Treble N'Bass Mk2 amp that I am haveing a bit of trouble with. It has a quite noisy 100hz, that is comming through the PI. I have narrowed it down to the PI since when pulling the tube, the noise goes away.
I have also discovered that if I add a capacitor over the negative feedback resistor, then the noise goes away. However this causes the bias on one of the tubes to go to like 45Am, and the other is at 17Am (this can however be fixed be adding a pot to each tube)
But the thing is I would really like to figure out what the source of the noise could be. I have tried a lot of things, and nothing has worked except the capacitor method.
Im open for all Ideas, so please let me know. Also if you need more pictures.
Thanks in regards
Nikolaj
Re: 100 hz noise Selmer Treble N'Bass Mk2
« Reply #1 on: May 04, 2024, 03:38:19 pm »
Posted in wrong board........... moving
