September 16, 2026, 11:37:35 pm
Hoffman Amps Forum image Author Topic: Univox ; fuse issue  (Read 4480 times)
Offline Latole
Univox ; fuse issue
« on: May 08, 2024, 03:29:08 pm »
The story began here ; https://el34world.com/Forum/index.php?topic=31632.0
_____________________
Summary; Univox U 1246 head
New 6L6GC
50% ( and less ) bias and blown fuse.
Filter caps to be replaced?  They are original
Output transformer
Power transformer ?
The customer has always used an old guitar wire between this head and the cabinet.
Then he noticed that the wire was cut........
_______________________
The story in detail;
Used Univox amp only worked a few hours after purchase. The fuse blew.
A 6L6GC vintage short power tube caused the problem.
Put 2 JJ 6L6GC specified 30 watts on the Tubes Store
Did the bais at 50%; 22 ma / 716 vdc plate.
The amp worked at idle and playing for hours at a time at home; not at maximum volume.
The customer (once at home) played very loud, bridged channels and a fuzz pedal.
After 30 minutes, the fuse blew.
I went to his place; the bias had not moved.
Adjusted it to 35% cooler (?) 8 to 10 minutes later; fuse blew Still playing very loudly.
Put in other tubes; no change except that the fuse was blowing faster and faster.
What do you think ?
Replace filter caps and / or....?
Offline Latole
Re: Univox ; fuse issue
« Reply #1 on: May 09, 2024, 05:49:14 am »
I remind you that the amplifier works perfectly at "reasonable" volume.
