September 17, 2026, 08:49:54 am
Hoffman Amps Forum image Author Topic: Fender Deluxe Reverb Mojo Tone kit Channel 2 problem  (Read 5764 times)
Offline SMSgtCC
« on: May 09, 2024, 08:37:08 pm »
Just completed build of Deluxe Reverb - Mojo Tone kit.
Normal channel loud, treble and bas respond nicely.
Vibrato channel: Weak output, no reverb or vibrato.
So far, swapped all the small tubes (12AX7 and the two 12AT7's). Verified connections and solder joints to tube sockets, jacks on back of chassis, and on back of pots and board.
What can I try next?
Thanks.
Offline passaloutre
Re: Fender Deluxe Reverb Mojo Tone kit Channel 2 problem
« Reply #1 on: May 09, 2024, 10:06:17 pm »
Do you have a signal generator and a listening probe?
Offline SMSgtCC
« Reply #2 on: May 09, 2024, 10:17:41 pm »
I'll take voltage readings at pins on each tube socket and repost tomorrow - thanks.
Offline SMSgtCC
« Reply #3 on: May 09, 2024, 10:18:52 pm »
No - I don't have either of those.
Offline passaloutre
« Reply #4 on: May 09, 2024, 10:34:40 pm »
You can make a probe with some wire and a capacitor, and you can use a smartphone as a signal generator. These tools help you find where you’re losing the signal.
Offline SMSgtCC
« Reply #5 on: May 09, 2024, 11:17:44 pm »
That's sounds very useful. I will look into that - thanks!
Offline SMSgtCC
« Reply #6 on: May 10, 2024, 07:12:42 am »
Voltage Readings: 5/10/24 05:45 AM
   Pin: Voltage
V1   1: 190
   3: 1.43
   6: 196.6
   8: 1.46
V2   1: 184.8
   3: 1.40
   6: 184.7
   8: 1.46
V3   1:  414.0
   3: 7.412
   6: 184.7
   8: 1.46
V4   1: 189.3
   3: 1.58
   6: 191.2
   8: 1.57
V5   1: 409.4
   3: .1 mV
   6: 360
   8: .5 mV
V6   1: 198
   3: 70.4
   6: 198
   8: 70.4
*V5 measurements don’t agree with schematic except for pin 6.
Offline tdvt
« Reply #7 on: May 10, 2024, 07:28:16 am »
Just for reference, assuming THIS one..
Offline SMSgtCC
« Reply #8 on: May 10, 2024, 07:31:38 am »
Yes - I believe so. The kit came with revision 5 of this schematic.
Offline SMSgtCC
« Reply #9 on: May 10, 2024, 07:56:52 am »
Found it. Yellow wire ("Y" on original layout) that connects to .1 cap - other side of this cap connects to pin 6 on V4 - that wire had come lose - bad solder joint underneath board. Thanks everyone!
« Reply #10 on: May 10, 2024, 08:12:17 am »
V5 reading are OK. Both triodes are in hard cutoff because there is no footswitch connected. You can enable the tremolo by grounding the tip of the FS jack. Then voltages will look much different and the tremolo will work.
V3 is a concern. Pins 1, 6 are jumped together and should have the same voltage. Pins 2, 7 are jumped together and should have the same voltage. Pins 3, 8 are jumped together and should have the same voltage. Your different voltages indicate you did not put the three jumpers on the socket. (This is not causing the weak vibrato channel)
Show us some hi-rez pics. Resolution should be good enough to clearly read resistor values.
« Last Edit: May 10, 2024, 08:14:36 am by sluckey »
Offline SMSgtCC
« Reply #11 on: May 10, 2024, 08:17:58 am »
Offline stratomaster
  • Don't guess, measure.
« Reply #12 on: May 10, 2024, 05:28:51 pm »
You still need to chase down Sluckey's observation above.  Your reverb driver is not where it should be.
