September 17, 2026, 10:00:54 am
Hoffman Amps Forum image Author Topic: Replacement circuit for Marshall DSL40c V1 amplifier  (Read 5764 times)
Offline RodrigoEliedson
« on: May 10, 2024, 03:27:55 pm »
Hi, guys
I have e DSL40C that has a lot of issues and a not good sound.
I would like to ask you guys if is it possible to replace marshall PCB for a one channel el34 base amp board, to work with marshall cabinet, transformers, pots, tubes and etc?
If yes, witch sellers do you recommend me to buy this kit/components?
It's a bad idea?
Cheers!!!
« Last Edit: May 10, 2024, 03:57:28 pm by RodrigoEliedson »
Offline Latole
Re: Replacement circuit for Marshall DSL40c V1 amplifier
« Reply #1 on: May 11, 2024, 03:44:15 am »
The DSL40 has 2 channels and you would like to replace the whole circuit with a single channel board.
I doubt it's possible.
1- To find a board
2- to fit the board in the amp.
I could be wrong.
Can't the current circuit be repaired? That is the best option
« Reply #2 on: May 11, 2024, 07:44:23 am »
Yes, it's possible. Hoffman sells the board and parts for a Plexi 50. This is not a paint-by-numbers kit, and the linked drawings are the only instructions. Requires electronic knowledge and basic fabrication skills, tool, etc. Are you up to the task?
Offline Latole
« Reply #3 on: May 11, 2024, 02:31:10 pm »
Offline Esquirefreak
« Reply #4 on: May 11, 2024, 03:02:43 pm »
Use the chassis and transformers to build something else. It'll be fun! And way more durable than a DSL 👍
/Max
Offline Latole
« Reply #5 on: May 11, 2024, 03:12:02 pm »
He may need a layout .
Why not this one ?   https://robrobinette.com/How_the_Marshall_JCM800_Works.htm
