September 08, 2026, 06:46:32 pm
Hoffman Amps Forum image Author Topic: Hoffman Single Channel AB763-1 Annoying 60Hz Buzz  (Read 7506 times)
Offline TexasTone
« on: May 13, 2024, 02:29:41 pm »
First of all, the amps sounds great and plays great.
The board is the Hoffman AB763-1 board.
Heaters center tap is elevated 70V via a voltage divider off the C node.
All the input and speaker jacks are isolated from the chassis.  Inputs are grounded to the preamp ground buss- board mounting screw closes to left-front of the amp, near where the first input jack would be.
The Power Amp ground includes:
   Speaker jacks
   B+ Center Tap
   Heater CT via 70VDC voltage divider from Doghouse "C" power [C4].
   Bias supply circuit - caoc
   Power tube cathodes via 1Ω resistors.
   NFB circuit: 1kΩ NPB resistor to 100Ω NFB tail; tied to LTPI 27k tail resistor and 0.1µF LTPI AC shunt.
   C1/C2 100µF 350V Power Supply reservoir caps, Doghouse "A".   (I moved all filter caps to this ground for troubleshooting purposes, and this had no effect.
The issue is the annoying buzz.
  • Not affected by any front panel controls
  • Not affected by pulling V1-V4
  • Pulling V5, the long tail phase inverter, stops the buzz.
Here's what I've done so far:
  • Swapped the LTPI tube.
  • Reflowed solder on G1 ground bus.
  • Grounded 4.7k Mid resistor to ground lug of volume pot.
  • Moved LFO ground to preamp buss on turret board.
  • Validated heater phase.  All preamp pins 9 daisy-chain to both power tube pins 7.
  • Added external 22µF-500V electrolytic across C1, C2, C3, C4, C5, one at a time.
  • Grounded all filter caps to power amp ground - per Hoffman_AB763_1.PDF page 2 grounding.  Previously, B, C, and D nodes were on preamp ground.
Nothing has made any difference.
Asking for help.
Thanks.
Offline AlNewman
Re: Hoffman Single Channel AB763-1 Annoying 60Hz Buzz
« Reply #1 on: May 13, 2024, 03:35:48 pm »
Since pulling your PI eliminates hum, I would think it could be caused by your speaker and nfb being grounded to your reservoir.
« Reply #2 on: May 13, 2024, 03:54:04 pm »
Does the buzz go away if you disconnect the NFB wire from the speaker jack or the board?
Offline TexasTone
« Reply #3 on: October 16, 2025, 02:38:00 pm »
Latest.
I moved some grounds.  The issue now is that the entire amp chassis is microphonic.
Pull V1 preamp.  No change.
Pull V2 reverb driver.  No change.
Pull V3, reverb recovery / PI driver.  Totally silent.
I tried three different tubes in V3, a new JJ, and NOS GE, and a NOS RCA.  The entire amp is microphonic no matter which one.
I'm going over the V3 circuit with a fine-tooth comb, but so far, nothing.
« Last Edit: October 16, 2025, 02:43:39 pm by TexasTone »
Offline passaloutre
« Reply #4 on: October 16, 2025, 02:54:20 pm »
There is a component in the signal path with a loose connection.
« Reply #5 on: October 19, 2025, 07:11:28 pm »
Latest.I moved some grounds.  The issue now is that the entire amp chassis is microphonic.Pull V1 preamp.  No change.Pull V2 reverb driver.  No change.Pull V3, reverb recovery / PI driver.  Totally silent.I tried three different tubes in V3, a new JJ, and NOS GE, and a NOS RCA.  The entire amp is microphonic no matter which one.I'm going over the V3 circuit with a fine-tooth comb, but so far, nothing.
Check that all input jack tip-switch contacts are making firm connection with the jack tips when there is no plug inserted. Even a slightly open connection will rattle microphonically. You can verify this by pressing the tip switches against the tips to see if the hum stops. The fix is to re-tension the tip switches slightly to make firm contact.
Offline AlNewman
« Reply #6 on: October 20, 2025, 12:26:01 am »
Can you isolate the problem?  I happens with the reverb level at 0?  What happens if you unplug the reverb tank?  Ground the grid of V3a pin 2?   Ground the grid of V3b pin 7?
Offline TexasTone
« Reply #7 on: October 28, 2025, 05:15:41 pm »
I checked the input jack grounds and they're good.
With no preamp tubes and a pair of 6L6GC tubes the amp has no noise.
Add a new 12AX7 LTPI V5.  No noise.
Add a new 12AX7 tremolo LFO and driver V4.  No noise.
Add a new 12AX7 Reverb Recovery and Vibrato Preamp 3 V3.  Lots of noise at both 60Hz and 120Hz, with the 120Hz being 6dB louder.  I traced all the wiring from the tube to the board and it's wired correctly.
Unplugging the reverb tank had no effect.
Grounding the grid of V3a pin 2 has no effect.
Grounding the grid of V3b pin 7 is a mixed bag.  The 60 Hz hum goes away, and the 120Hz hum is 11 dB louder, and I have an additional 180Hz hum that wasn't there before.
The wire lead from V3 pin 7 to the Reverb attenuator grid leak resistors seems to be an antenna, so I'm tracking that down.
Thanks.
Offline TexasTone
« Reply #8 on: November 05, 2025, 11:13:13 am »
The 120Hz and 180Hz hum is gone.
I changed the heater elevation from 45V to 68V.
I changed the wire from the reverb attenuator to V3 pin 7 to a shielded cable.
I changed the NFB resistor values.
The only issue left is this crazy microphonic on V3, the reverb recovery/stage 3 preamp tube.  The microphonic manifests itself especially on the turret where the wire that connects pin 7 to the 470k attenuator resistor.  When I put a chopstick on the tube socket shield base and then slide it to the body of the tube, you can hear every movement through the speaker.
Okay, bad tube.  Well, I used at least four different tubes - JJ, EHX, NOX GE, etc., and it's still microphonic.  Well, what about the socket itself?  It's a Beldon Micalex, and I'v cleaned and re-tensioned the pin sockets, and validated every solder joint.
Quite baffling at this point.
Offline stratomaster
  • Don't guess, measure.
« Reply #9 on: November 05, 2025, 05:56:29 pm »
There's a likelihood that the 10pF bypass cap is microphonic. Also that part of the circuit is always pretty noisy in my experience. It's very high impedance.  I try to give it every advantage with respect to noise, so the shielded wire is a good move. I also make sure the 3.3M is a good low noise metal film.  I also tend to use 3M here, as it's still technically in tolerance for the AB763.
You can also try a 22k gridstopper right at the socket, but I don't see that helping much.
Offline TexasTone
« Reply #10 on: November 07, 2025, 12:16:42 pm »
Latest Update.
First of all, thanks to all for your input!  We are complete with a fantastic sounding amp.
Some of the changes:
  • Replace C33 & C34 with two 100µF 350V caps in series with parallel 220k resistors.
  • Separate the A node grounds (to power amp ground) from the B, C, and D node grounds (to preamp ground).
  • 70V heater elevation.
  • Add 100k resistor before C22.
  • Changed R45 & R51 NFB resistors to more preferable and less noisy values.  The stock values of 820Ω and 100Ω attenuates the output signal 89%.  My number is closer to 85% for this particular amplifier.
  • Changed C28 to .022µF.
  • Changed R63 to a lower value than 470k
  • Changed C31 to .047µF.
    • Tubes: V1=E83CC; V2=12AU7; V3=12AY7 Gold pin; V4=12AX7; V5=12AX7; V6 & V7=6L6GC.
    • 5AR4 replaced by diodes.
    Various other secret sauce mods . . .
Offline SEL49
« Reply #11 on: November 07, 2025, 01:06:24 pm »
I bet they are not really connected like this...   :icon_biggrin:
Offline TexasTone
« Reply #12 on: November 11, 2025, 04:11:24 pm »
Yeah, I know, it's just a drawing error.  LOL
« Reply #13 on: November 11, 2025, 05:49:58 pm »
and that's why we troubleshoot with schematics not layouts, schematics get a better quality draftsman  :icon_biggrin:
