September 18, 2026, 10:49:01 pm
Hoffman Amps Forum image Author Topic: 6G6 Bassman-ish Bias Issue  (Read 4550 times)
Offline Skeeter_pdx
  • Certified Unc
« on: May 14, 2024, 07:00:11 pm »
An amp came to me after a power tube was inserted misaligned, there was an explosion and a smell and sure enough the screen grid resistor was blown to smithereens. I put new 470 ohm screen grids in, went to check voltages, and got -52v DC for the bias on one output tube while the other had -42v. Both of the grid leak resistors measure 220k, and I put in new coupling caps from the PI to make sure there was no DC leakage from an old cap. I’m a little stumped on where else to look for issues. Its not exactly a 6G6, but it’s close enough https://el34world.com/charts/Schematics/files/fender/Fender_bassman_6g6_schem.pdf
Re: 6G6 Bassman-ish Bias Issue
« Reply #1 on: May 14, 2024, 07:50:41 pm »
Not much on a real 6G6 that would cause the bias voltage to be different on pins 5. You've already eliminated the coupling caps. Pull the output tubes and recheck the voltage on pin 5 of each socket.
Offline Dave
« Reply #2 on: May 15, 2024, 06:21:51 am »
Try a different set of output tubes and see what the numbers are.
Dave
