September 08, 2026, 04:43:15 pm
Hoffman Amps Forum image Author Topic: Master Volume 70's Fender - Convert to LARMAR Help  (Read 44068 times)
Offline Yeatzee
  • I like vintage!
Re: Master Volume 70's Fender - Convert to LARMAR Help
« Reply #50 on: May 27, 2024, 05:28:29 pm »
Put a bright cap across the two wires at the mv pot. I'd try 47pf, 100pf, 120, just whatever is handy. Need one cap on each pot. Any better?
All out of caps in those small sizes  :BangHead: Guess I'll order some and circle back in 5 days
Bear with me, I'm learning!
www.youtube.com/c/YeatzeeGuitar
Offline stratomaster
  • Don't guess, measure.
« Reply #51 on: May 28, 2024, 12:46:52 pm »
Scavenge them from the bright switches for proof of concept.
Offline tdvt
« Reply #52 on: May 28, 2024, 01:02:03 pm »
I have done just 2 LarMar MVs; one in a Bassman, the other in a new Princeton-ish build & as you dial them down, both seem to lose bass quicker than mids or treble.
« Reply #53 on: May 28, 2024, 02:07:13 pm »
Our ears hear less bass as we turn down the amp. There's a 'fullness' to the sound once it's turned up some that we don't perceive as we turn down.
That's why they have a loudness button on stereos. Well, they used to anyway.  :laugh:
Offline tdvt
« Reply #54 on: May 28, 2024, 02:37:36 pm »
Agreed, & I was remembering  those old-school loudness buttons myself.
That's why I thought it odd he was losing top-end.
« Reply #55 on: May 28, 2024, 03:04:05 pm »
You also loose treble end as you turn the volume down.  That's why there is a bright cap on many volume controls.
Offline Yeatzee
  • I like vintage!
« Reply #56 on: May 28, 2024, 05:56:05 pm »
That's a good idea!
Offline Yeatzee
  • I like vintage!
« Reply #57 on: May 29, 2024, 01:53:33 am »
Reporting back, happened to have one 100pF cap and then stole the normal channel 120pF for the other one to do the test. Then I also found two 500pF caps in my inventory to try and compare.
100pF to my ears appeared to do very little, certainly wasn't noticeable as the player... yet 500pF was a huge difference and too bright / thin as you turn down. So looks like I'll need to order something inbetween and give that a try
« Reply #58 on: May 29, 2024, 04:40:12 am »
The most likely root cause of the treble loss issue is the use of 1M pot.
Due to the effective source resistance, that interacts with the output valve's Miller capacitance, rising to 250k at the electrical mid point.
If the goal is to maintain a more inherently linear frequency response over the range of the pot's rotation, then a lower value pot, eg 220k, 100k, may be beneficial.
« Reply #59 on: May 29, 2024, 06:37:48 am »
You have good ears. Trust them. Get a variety pack of small caps and also get some 100K and 250K pots. Experiment until your ears are happy. Let us know your results.
« Reply #60 on: May 31, 2024, 01:36:25 pm »
You can also try a resistor in series with the bright cap.  It'll mess with the pot taper some, but you're in experimentation mode anyway.
If you have a 50k trim pot or so put that in series with the 500pF across the lugs.  As you turn the master down tweak the trim pot to give you the treble response you're looking for.  You'll probably find a suitable value that behaves acceptably through most of the range.
Note: you're more ambitious than I. I would've moved the existing pot to a simple cross-line MV and wired the pull switch to double the negative feedback or disconnect two of the 6L6 cathodes for a "half power" option, buttoned this up and moved into the next repair long ago.
« Last Edit: May 31, 2024, 01:38:36 pm by stratomaster »
Offline Yeatzee
  • I like vintage!
« Reply #61 on: June 09, 2024, 04:41:23 pm »
Played with it some more, and ultimately couldn't find a combination I loved. Ended up trying to make the Larmar work and am happy with the results. Instead of jumpering the two bias feeds to the two gain pot inputs, I just ran the two separate feeds from the bias balance to the two separate inputs on the dual pot. Used a 100k pot since the bias leak resistors were 100k.
i=IoA8OJtBk5TxlEMg
« Last Edit: June 09, 2024, 04:43:35 pm by Yeatzee »
« Reply #62 on: June 09, 2024, 05:11:34 pm »
Nice job. Glad you got it sorted out.
« Reply #63 on: June 10, 2024, 12:31:44 pm »
The 1M safety resistor puts you at the low end of the tolerance band for the grid/bias leaks not including the tolerance of pot itself.  This is likely fine, but the usual 2.2M puts you back in the 5% range.
A safety check you can do since you're messing with bias with this type of master volume is confirming the voltage at the grid pin of each socket.  This will give you a clue as to whether your arrangement is disturbing the bias somehow, and if you remove the tubes you can test that you've fully preserved the bias and balance functions by tracking the voltages at each grid as you rotate each bias pot.
Good work.
Offline Yeatzee
  • I like vintage!
« Reply #64 on: June 10, 2024, 03:32:41 pm »
Good work.
Yeah I confirmed the bias voltage with no tubes in it before putting them in and at the grids it matched the bias voltage straight off the pot. I should have shown that on video, but I was rushing to get it done before the owner came by. He texted me later saying it sounded incredible and he's super happy with it so it all worked out!
« Reply #65 on: June 10, 2024, 03:50:26 pm »
The actual value of the grid leak resistors is not critical. It's more important that they are equal value.
Offline tdvt
« Reply #66 on: June 10, 2024, 04:35:18 pm »
I recently played a date with the guy whose BF Bassman I converted to a combo & included a LarMar, as stage volumes are now quite low.
He was really happy & from where I was on the small stage, I thought it sounded great. With the MV set about 1/2, it wasn't too loud (we were all worried) & it had a really nice clarity that you wouldn't associate with using a MV.
Pic added;
It's not a lot bigger than a Princeton but with WAY more under the hood, so a usable MV makes all the difference.
« Last Edit: June 11, 2024, 12:50:54 pm by tdvt »
Offline mountainhick
« Reply #67 on: April 04, 2026, 11:54:46 am »
i=IoA8OJtBk5TxlEMg
Dredging up an old one...
Thanks for traveling this path first! I just did this with a Bassman ten remod (though PI and bias circuit modded to AA864 values with the balance pot remaining). Seems to work well
@pdf64:
For a type 2 / LarMar to work, the bias balance will need removing and converting to the previous type of shared bias adjustment.
Which seems a beneficial thing to do anyway?
Pete, any further thoughts on this, is there an unseen problem using bias balance and larmar this way that I am not seeing? Seems to work, and sounds so much better than the KOC style I had in it.
« Last Edit: April 04, 2026, 11:57:44 am by mountainhick »
« Reply #68 on: April 05, 2026, 04:06:42 am »
I think the bias balance pot will tend to cause prevent adequate AC decoupling when a type2 / LarMar is set to minimum CCW, and seems likely to cause an imbalance between the balances signals at lower settings.
If it's working well for you then carry on, sorry to cause concern, don't worry about it  :icon_biggrin:
« Reply #69 on: April 05, 2026, 08:44:36 am »
Trying to visualize this in the circuit: signal crossover between sides, or AC from the bias supply?
It does sound like crap at super low volume with the modded high gain channel.
I am not prone to want to run it at bedroom volume, that's for other amps. More like 50% or more on the pot rotation.
I may try removing the balance pot anyway just to see, but that is a bit of work to do and redo if I go back.
« Reply #70 on: April 05, 2026, 09:51:31 am »
A decoupling cap (eg 10 to 47uF 100V) at either end of the balance pot would fix the issue I raised.
« Reply #71 on: April 05, 2026, 10:28:02 am »
i.e. to ground?
There is one on the supply side of the balance pot.
« Reply #72 on: April 05, 2026, 03:36:18 pm »
i.e. to ground?
Yes, to ground.
Either add 2 more caps, or move the one at the wiper to one track end, and add a cap to decouple the other track end.
