July 25, 2026, 10:56:10 pm
Hoffman Amps Forum image Author Topic: Chassis fab  (Read 4941 times)
Offline fossilshark
  • No life til' leather
Chassis fab
« on: May 30, 2024, 07:12:35 am »
Hi all, sorry if this question has been asked before. I recently aquired an old school sheet metal brake bender and hefty drill press. I am only trying to figure out now how to cut the patterns for chassis.
For best results would a laser cutter be ideal? Does anyone have any recommendations under $2k?
What do you all do as a solution for this issue?
Any advice is greatly appreciated.
~SNOWBLIND~
Offline j-b-c
  • sparks!
Re: Chassis fab
« Reply #1 on: May 30, 2024, 09:21:37 am »
Be sure to leave enough space for the bends.
https://en.wikipedia.org/wiki/Bending_(metalworking)#K-factor
Lots of suppliers will laser cut flat sheet.
Practically all CAD programs will have settings for the K-factor of the sheet material.
Offline acheld
Re: Chassis fab
« Reply #2 on: May 30, 2024, 09:53:04 am »
I think it depends on your projected volume, what you're trying to accomplish, how much space and power you have, etc.
I normally use 14ga aluminum plate for my chassis builds -- just use my wood tools (with carbide blades/bits) to make cuts, and lots of lube, with good enough precision.
If I was going to spend a chunk of cash, I'd pony up for a Shaper Origin -- lots of different uses for that.   So far, hard for me to justify the expense.
Doug's got a lot of experience with CNC machining.  I'd be interested in his take on the question.
