September 09, 2026, 04:10:06 am
Hoffman Amps Forum image Author Topic: PT questions  (Read 13206 times)
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
PT questions
« on: June 05, 2024, 05:30:11 pm »
Hey guys !
I got this PT from a Geloso 268 reel to reel. Schematic attached.
The PT itself is confusing as you can see in the picture, heaters wires in the same side of primary wires.
The insulation on the wires are crumbling but the windings give readings.
Except for the purple wire, not even connected with the core.
I got some questions:
1- The HT winding(orange) read 35k ohms, is this right? readings attached
2 - What is the grey and blue windings for ?
3 - Advice replacing the wires ?
Thanks in advance !
https://soundcloud.com/ukiuki
Re: PT questions
« Reply #1 on: June 05, 2024, 05:47:55 pm »
1- The HT winding(orange) read 35k ohms, is this right? readings attached That's bad!
2 - What is the grey and blue windings for ? Grey is for a lamp bulb. Blue is to power three solenoids.
3 - Advice replacing the wires ? Run like hell!
Actually I have a good idea how to replace the wires but since the HT winding is shot, why bother?
Offline uki
    • Uki's Guitar Trip
Re: PT questions
« Reply #2 on: June 05, 2024, 05:57:32 pm »
:huh:
  :laugh:
Please tell me,
after seen this video
, i may try to fix the PT.
Re: PT questions
« Reply #3 on: June 05, 2024, 06:34:19 pm »
insure your fire extinguisher is electrical fire rated  :icon_biggrin:
Re: PT questions
« Reply #4 on: June 05, 2024, 08:02:08 pm »
Why? The HT winding is bad or has a bad connection to those rotten wires. 35K is ridiculously high. That winding should read 200Ω or less.
Put some voltage on the primary and measure the secondary voltages before doing anything else.
Offline uki
    • Uki's Guitar Trip
Re: PT questions
« Reply #5 on: June 06, 2024, 02:29:05 pm »
I did that !!  After some caring with the wires we dont want things to explode right!!  :blob8:
My line was giving 117vac at the test moment.
Through a down step PT 120 to 12v
into the 110v primary of the PT.
The HT was giving 21.3v output !
Heater across wires 0.8v and sides with CT about 0.4v
The grey wind 2.3v
and the blue wind 0.78v
Is it good ?
« Last Edit: June 07, 2024, 01:30:33 am by uki »
Offline johnnyreece
Re: PT questions
« Reply #6 on: June 07, 2024, 07:46:10 am »
Is it good ?
Hard to say.  Is there any indication what the HT winding is supposed to be?
Re: PT questions
« Reply #7 on: June 07, 2024, 08:54:08 am »
The voltages appear normal. I'm still concerned about that high resistance reading on the HT winding. Could you measure that again?
Offline uki
    • Uki's Guitar Trip
Re: PT questions
« Reply #8 on: June 07, 2024, 11:05:36 am »
I did, several times, all times the voltage was the same 21.3v on HT...
But,  the resistance did change almost every time it was plugged/unplugged
2.7k at the first reading today!!  I was really surprised, what happened to that 35k :dontknow:
it was the result after reading more than once yesterday...
So 2.7k at fist then 6.5k , 8.6k , 9.5k, then back to 6.5k and changed again...
The PT was unplugged between ohms and volts read.
I did read with three different multi meters to make sure.
thoughts ?
Thanks !
« Last Edit: June 07, 2024, 11:09:22 am by uki »
Re: PT questions
« Reply #9 on: June 07, 2024, 11:15:20 am »
All of those DCR reading are way high. Most likely a bad connection where the tiny winding wire is soldered to the external lead. You would still get a correct voltage reading, but as soon as you connect some load to the winding the voltage will likely go way down. I suggest connecting 120VAC to the primary and measure the HT winding voltage. Then connect a 10K 10W resistor across the winding and see what happens to the voltage.
Offline uki
    • Uki's Guitar Trip
Re: PT questions
« Reply #10 on: June 07, 2024, 11:53:07 am »
Reading the PT voltage connected to 115vac, without the resistor the output is  161v
with the resistor output is 156v
Now the surprising part, after unplugging and reading ohms it does give way less now, i did repeat the process a few times
readings are: 471r , 431r , 444r , 454r
thoughts?
Re: PT questions
« Reply #11 on: June 07, 2024, 04:33:47 pm »
thoughts?
Meter battery?
Offline uki
    • Uki's Guitar Trip
Re: PT questions
« Reply #12 on: June 08, 2024, 06:29:15 pm »
Meter battery?
Well
....I did read with three different multi meters to make sure.
One with new battery, This variation only happen with the HT wind.
... Most likely a bad connection where the tiny winding wire is soldered to the external lead. You would still get a correct voltage reading, but as soon as you connect some load to the winding the voltage will likely go way down.
Ain't 161v and 154 with 10k/10w resistor, too low for the HT?
Thanks !
Re: PT questions
« Reply #13 on: June 08, 2024, 07:36:21 pm »
160vac can make 226vdc with a fwb. Might be just right for that recorder.
Offline uki
    • Uki's Guitar Trip
Re: PT questions
« Reply #14 on: June 09, 2024, 01:24:57 am »
How would you do it ?!
Offline uki
    • Uki's Guitar Trip
Re: PT questions
« Reply #15 on: December 19, 2024, 03:01:33 pm »
Back to this PT, giving a go on restoring the wires connections.
it is been a surgical procedure!  :icon_biggrin:
Maybe someone have some advice/ideas.
Thanks in advance!
Re: PT questions
« Reply #16 on: December 19, 2024, 03:12:21 pm »
Some time ago It happened to me to change the wires of a PT, they were chewed by mice, but honestly situation was way better than what I see in your photo
Offline uki
    • Uki's Guitar Trip
Re: PT questions
« Reply #17 on: December 20, 2024, 09:41:32 am »
Some update !
I got the wires fixed !  There is that purple wire but it isn't connect to anything...
1- what to do with the purple wire? (the one between the orange and grey in the pic)
2- what would be a good way to now insulate the transformer wires, before reassembling?
« Last Edit: December 20, 2024, 09:45:43 am by uki »
Re: PT questions
« Reply #18 on: December 21, 2024, 08:23:53 am »
Nice job but ....... I'm not sure it is also a good job, why I say so ? Because joining the insulated wires to the windings in that way you enlarged the structure
If when covered with some paper turns all fit on laminations, you are fine but if the thickness is too, the risk is your windings don't fit in lamination (EDIT: I forgot to add End Bells) space
The doubt is here because whey they builded the transormer they connected the wires in a way to prevent the insulation was under the paper
« Last Edit: December 23, 2024, 02:25:02 am by kagliostro »
Offline Merlin
Re: PT questions
« Reply #19 on: December 21, 2024, 10:18:44 am »
Is it an internal screen?
You orange wire solder joint looks like it could use some more solder
Maybe a spear of epoxy glue?
« Last Edit: December 21, 2024, 10:27:14 am by Merlin »
Offline uki
    • Uki's Guitar Trip
Re: PT questions
« Reply #20 on: December 23, 2024, 06:06:06 pm »
Thanks Merlin and Franco!
I did a recheck on the solders!
I don't know, in the schematic looks like the purple goes to the core of the PT, am I reading it right?
Another thing that i don't get it, the supposed filament wires, in the schematic are on the secondary side. They read on the PT 3.4v on each side,
but on the PT the supposed filament wires on the primary side, and on the secondary there is two wires without center tap that read 6.5v
Which ones should be used for filaments ?
Re: PT questions
« Reply #21 on: December 24, 2024, 01:24:26 am »
You say there are wires on the primary that you suppose to be heater wires
Are those wires connected to the primary windings ?
If they are they are not heater windings, the purpose is to adapt the primary to the voltage of your line, but 3.4v is a low adjustment, so seems this isn't the pourpose
If they are stand alone (not connected to the primary) they are for heaters and the connections are near the primary windings simply for space reasons
The other windings (6.5v) are also at heater level
Assuming both windings are not connected to other windings, as you measure 3.4v-0-3.4v (6.8v) and 6.5v it may be that at the windings that measure the higher voltage there is more current available
Observe the thickness of the wires of the windings and/or connect a load to see which ore has more current
« Last Edit: December 24, 2024, 01:30:34 am by kagliostro »
Offline Merlin
Re: PT questions
« Reply #22 on: December 24, 2024, 04:58:06 am »
That is certainly possible.
It looks like the PT has two HT windings, and two heater windings. One HT winding and one heater winding are for the amp in the schematic, and the other pair go to a separate preamp unit that would be plugged into that octal socket. So I guess you can use whichever heater winding you like. Brown-brown probably has a higher current rating since it supplies the power tube.
« Last Edit: December 24, 2024, 05:01:05 am by Merlin »
Offline uki
    • Uki's Guitar Trip
Re: PT questions
« Reply #23 on: December 26, 2024, 06:34:53 pm »
Some update!
The wires are insulated, the core is back in place. Tests tomorrow.
Only have done ohms reading it is the same as before.
What is the purpose of the purple wire?
Offline Merlin
Re: PT questions
« Reply #24 on: December 26, 2024, 06:39:02 pm »
If you have tested it correctly, it is to ground the core. It may also be connected to an internal screen.
Offline AlNewman
Re: PT questions
« Reply #25 on: December 26, 2024, 08:59:48 pm »
That looks really good.  I hope your tests go well.
Offline uki
    • Uki's Guitar Trip
Re: PT questions
« Reply #26 on: December 27, 2024, 01:56:50 pm »
Thanks Merlin !
Yeah it is now giving solid readings
brown/blue/brown - 6.6vac
oranges - 164vac
greys - 19vac   what is this for?
blues(no CT) 6.4vac
some pics of how it was when it was in the device, wires dried out, crumbled, melted, it is really surprising it does still work!
Next step is to build an amp  :icon_biggrin:
« Last Edit: December 27, 2024, 02:31:46 pm by uki »
