August 29, 2026, 09:11:20 pm
Hoffman Amps Forum image Author Topic: Deluxe Reverb to Single Channel w/ No FX Voltage Question  (Read 5590 times)
Offline Thisismyname
  • I love sound!
« on: June 05, 2024, 07:52:00 pm »
This amp used to be a AB763 DR Clone. Then it was a genuine pig for mods while I learned about amps. A mess of circuitry. Now I need it for gigging at lower volume with pedals. I need simplicity (which I've found is best anyway) The preamp and FX are already removed from the amp.
The easiest and cheapest method would be to turn it into a DR normal channel preamp going into the stock power amp etc. I'll add a tone stack bypass control for extra gain if I need it. Vibrato channel, reverb, and tremolo circuits would be excluded.
My question is this: since the DR already has pretty high voltages, do I have to worry about even higher voltages with all those other circuits being absent? Would it be a problem?
« Last Edit: June 05, 2024, 08:02:49 pm by Thisismyname »
Re: Deluxe Reverb to Single Channel w/ No FX Voltage Question
« Reply #1 on: June 05, 2024, 08:28:27 pm »
No worry. No problem.
You may be interested in this...
     https://sluckeyamps.com/misc/AB_Lite_II.pdf
  • I love sound!
« Reply #2 on: June 05, 2024, 08:31:55 pm »
Thank you, Sluckey!
