August 29, 2026, 09:10:38 pm
Hoffman Amps Forum image Author Topic: LDR testing Mesa Boogie  (Read 5277 times)
Offline joesatch
  • save me from myself.
« on: June 12, 2024, 01:59:17 pm »
Is there a process for testing these?  Continuity testing wont work. I've measured the resistance between the poles when the LDR receives +/- 1.5vdc. When not activated i'm getting 10M when active i get 2.7k. I have another which just reads very inconsistent activated 10M not activated 1M (but not always). How do i determine what LDR's are bad?
Offline joesatch
Re: LDR testing Mesa Boogie
« Reply #1 on: June 12, 2024, 02:09:00 pm »
due to what the ldr's are connected to i believe these must be tested out of circuit?
« Reply #2 on: June 12, 2024, 02:27:17 pm »
I would disconnect only the two LDR legs if possible. Then there will be nothing in parallel with the LDR. Resistance should be very high or fairly low.
