September 08, 2026, 04:41:58 pm
Hoffman Amps Forum image Author Topic: Marshall bass spec (sort of) build schematic review.  (Read 9062 times)
Offline theRagman
  • [0] days since my last soldering iron burn
« on: June 15, 2024, 01:07:04 pm »
I have the transformers from a Marshall-esque amp that I'm hoping to reappropriate into a sort of simplified 50-watt Marshall bass spec. I've only built from a kit before, so any guidance you folks can provide me would be much appreciated.
It's kind of a weird deal, since the original amp I got the transformers from was a 50-watt amp with a 100-watt power transformer. I've tried to diagram that power supply as it was in the original amp and stared at it six ways from Sunday, but I would not be at all surprised if I've done something stupid here.
Schematic attached.
Thanks!
Re: Marshall bass spec (sort of) build schematic review.
« Reply #1 on: June 15, 2024, 02:39:13 pm »
Schematic looks good to me.
Offline theRagman
« Reply #2 on: June 15, 2024, 07:03:17 pm »
Thank you!
Offline Latole
« Reply #3 on: June 16, 2024, 04:00:56 am »
Wouldn't the bais adjustment circuit be better like this?
« Reply #4 on: June 16, 2024, 05:39:49 am »
His Marshall bias circuit has been working very well for Marshall for over 50 years.
Offline Esquirefreak
« Reply #5 on: June 16, 2024, 05:50:39 am »
I'd use either 2*100μF or 2*200μF in series as first filter stage/reservoir caps in the power supply.
/Max
Offline Latole
« Reply #6 on: June 16, 2024, 06:39:30 am »
/Max
I agree , the Ragman's schematic show 2 X 50 mfd in series = 25 mfds
Marshall JCM800 Lead schematic show 2 X 50 mfd in parallel = 100 mfds
Offline theRagman
« Reply #7 on: June 16, 2024, 08:27:47 am »
/Max
Thanks! I wouldn't mind adding some more filtering, so that makes sense.
Offline theRagman
« Reply #8 on: June 16, 2024, 08:31:22 am »
Is there a general rule of thumb regarding safety margin on filtering caps? For example, B+ for this transformer is 460V, and the electrolytics that were in there were rated for 500V. I assumed they were put in series because the normal tolerances on those caps could easily result in one at a true voltage rating less than B+. Are there other considerations?
Offline Latole
« Reply #9 on: June 16, 2024, 09:38:43 am »
With Power Tube load, B+ may drop a bit.
On some Fender amps with 420 B+ I see 450 volts filter caps.
Deluxe Reverb AB763
« Reply #10 on: June 16, 2024, 09:41:41 am »
here's one of my "stiff" PS's
the in-rush, before tubes warm up exceeds the 500vdc rating, but "stacking" (in series) 2 350vdc caps = 700vdc at 1/2 the capacitance.
a good bleeder resistor comes in handy if you don't want to wait 15 minutes after power-OFF to NOT get zapped.  large capacitance PS have a tendency to hold a charge long after power is off.
« Reply #11 on: June 16, 2024, 01:48:41 pm »
Is the amp intended for bass or guitar?
Marshalls require a lot of power supply sag to achieve their characteristic overdriven response.
Additionally, the sag is required to protect the output valves from excessive dissipation.
A super stiff 100W capable power supply will sag very little when supplying a 50W amp.
Hence for overdriven guitar use, it won't respond like a Marshall, and the output valves may get overstressed.
Hence it may be better to sell that transformer and buy one that's more appropriate?
Offline theRagman
« Reply #12 on: June 16, 2024, 02:08:40 pm »
Hmm, that's interesting, and it may explain why I didn't really care for the amp I cannibalized it from. I was planning on using this mostly as a clean amp, but I think you've got a good point. If I could find an appropriate 50-watt transformer instead, that might be the way to go.
Offline theRagman
« Reply #13 on: September 28, 2024, 01:45:46 pm »
I finished wiring the amp up last night, and I'm happy with it. Thanks to everybody who weighed in on the schematic and kept me from going awry before I even got started. You folks are great!
