September 08, 2026, 07:54:02 pm
Hoffman Amps Forum image Author Topic: MAR-CHAMP  (Read 7547 times)
MAR-CHAMP
« on: June 16, 2024, 05:11:54 am »
Hey guys, This https://www.aggh.net/discussion/index.php?topic=51724.msg581099#msg581099
Got gutted last week, due to the lack of interest on my part.
It's now marshall 2144 preamp, champ power amp kinda.
All fired up well, haven't had a chance to chank it
Re: MAR-CHAMP
« Reply #1 on: June 16, 2024, 05:33:31 am »
Neat and tidy as usual!   :thumbsup:
Offline Latole
Re: MAR-CHAMP
« Reply #2 on: June 16, 2024, 09:54:34 am »
Very nice job.
Re: MAR-CHAMP
« Reply #3 on: June 16, 2024, 10:46:50 am »
Man, you are always coming up with such cool stuff!   Thanks for sharing, Tubenit
Re: MAR-CHAMP
« Reply #4 on: June 16, 2024, 02:20:43 pm »
Thanks guys.
I have a spare hole in the control panel...
Is there a way to add a presence control in an SE amp?
Offline passaloutre
Re: MAR-CHAMP
« Reply #5 on: June 16, 2024, 02:37:31 pm »
Yes, negative feedback can go to the cathode of that final triode stage.
I’m curious how you like the footswitchable boost on the first stage?
Re: MAR-CHAMP
« Reply #6 on: June 16, 2024, 03:14:23 pm »
Here's one way. Just play with the resistor values and I bet you will come up with something useful. I suggest to first add the NFB loop and get the phase sorted. Then convert to the presence circuit.
Re: MAR-CHAMP
« Reply #7 on: June 16, 2024, 05:03:32 pm »
for the alternative SE amp view;
plug into a Marshall full stack
move the guitar closer to the speakers, your presence will be soon known  :icon_biggrin:
Re: MAR-CHAMP
« Reply #8 on: June 17, 2024, 02:46:09 am »
 :l2:
Re: MAR-CHAMP
« Reply #9 on: June 23, 2024, 02:53:21 am »
Hi guys,
My stunt guitarist has had a bash and has given it a low rating.
The LOW input was given a 5/10 sounded good but when cranked didn't quite hit the mark with a smooth overdrive.
So the HI gain input was 1/10 with the sound "fracturing" at low volume and when the boost is engaged it would only sound OK at a very low volume.
Comparing the two circuits and voltages https://www.aggh.net/discussion/index.php?topic=54528.msg610886#msg610886
So my starting point was to drop nodes C and D to get a similar voltage to the preamp valves with an increase to the dropping resistor between nodes B and C to 20k
Even with this increase voltages and still a touch high.
I'll have a play with this with a thought to use an AT7 or AY7 in V1
