August 29, 2026, 09:12:42 pm
Hoffman Amps Forum image Author Topic: 5C1 with recovered material - V1 question  (Read 6248 times)
« on: June 28, 2024, 02:10:18 pm »
A friend has build, with old parts, a 5C1 amp
this is the schematic
The output level is satisfying if he uses a Signal Generator at the input, but is low if he use the guitar
There is way to arrange components aroud V1 (6B8 - he has a glass version of the tube) as to increase his output to the Power Tube ?
http://frank.yueksel.org/sheets/021/6/6B8.pdf
Re: 5C1 with recovered material - V1 question
« Reply #1 on: June 28, 2024, 02:20:01 pm »
Replace the 6B8 with a 6SJ7 and follow this schematic...
     https://el34world.com/charts/Schematics/files/Fender/Fender_champ_5c1_schem.pdf
« Reply #2 on: June 28, 2024, 02:25:24 pm »
 :l2: :l2: :l2:
OK
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« Reply #3 on: June 28, 2024, 05:31:29 pm »
What kind of pickups on the guitar? Some pickups have lower output than others, try another guitar?
https://soundcloud.com/ukiuki
« Reply #4 on: June 28, 2024, 05:58:29 pm »
Right it must be considered
« Reply #5 on: June 29, 2024, 03:46:29 am »
Seems that also a guitar with active pickup was tried without the desired result
I think he must swap V1 for one other tube or insert a gain stage (jfet) between input and V1
Offline jeff
  • Need input
« Reply #6 on: June 30, 2024, 05:30:05 am »
Dumb question, but, are the batteries in active pickups dying?
Sometimes the littlest things get overlooked.
« Reply #7 on: June 30, 2024, 07:27:52 am »
Don't know, I'll ask
