August 29, 2026, 09:12:13 pm
Hoffman Amps Forum image Author Topic: Marshall 6100 Power Supply Capacitors  (Read 4701 times)
« on: July 02, 2024, 09:25:11 am »
I have a hard time when it comes to finding the correct size Radial Capacitors for some amplifiers.This 6100 Marshall uses (4) 220uf 400vdc radial caps. I tried to search by the code on the caps but they were made back in 1991.CE LK (M) 9148
Also (2) 47UF 450VDC & (4) 33UF 350VDC Radial
« Last Edit: July 02, 2024, 09:27:54 am by plexi50 »
Re: Marshall 6100 Power Supply Capacitors
« Reply #1 on: July 02, 2024, 09:29:31 am »
Pic 33uf 350
« Reply #2 on: July 02, 2024, 09:45:26 am »
Pull the caps. Measure diameter and lead spacing. Shop at Mouser and consult the data sheets if needed.
