July 25, 2026, 03:32:54 pm
Hoffman Amps Forum image Author Topic: Correct component value  (Read 5538 times)
Offline isaac_teller
« on: July 03, 2024, 04:10:56 am »
Hello. In the schematic of the preamp of the Soldano SLO100 there are 2 symbols of a LED(VR1 and VR2). Usually VR stands for a potentiometer. Does anyone know if the actual component is a LED or a potentiometer? If so, what value? Thank you.
https://el34world.com/charts/Schematics/files/Soldano/Soldano_slo100.pdf
Online sluckey
Re: Correct component value
« Reply #2 on: July 03, 2024, 07:16:15 am »
The answer is right on the schematic you posted in the original post.
Offline Latole
« Reply #3 on: July 03, 2024, 07:30:35 am »
VR = Variable Resistor.
These VR in this amp are a light activate resistor
Online sluckey
« Reply #4 on: July 03, 2024, 07:46:48 am »
VR1 through VR4 are VTL5C1 opto-isolators and are used as on/off switches in this amp circuit. VR is a very poor reference designator for an opto-isolator.
Offline Latole
« Reply #5 on: July 03, 2024, 07:58:05 am »
What I see ;
Online sluckey
« Reply #6 on: July 03, 2024, 08:07:56 am »
What I see ;
... does not apply in this case. The VTL5C1 contains a LED that is electrically isolated from a LDR.
