July 25, 2026, 07:40:44 am
Hoffman Amps Forum image Author Topic: Peavey Classic VT output jacks  (Read 4420 times)
Offline Esquirefreak
« on: July 13, 2024, 06:27:45 am »
I got one of these for dirt cheap recently. At first it did sound very anemic. But after playing it through a decent speaker cab I gotta say that it sounds quite nice and has enough dynamics to allow riding the guitars volume knob.
I have some 12" speakers laying around, but they're all 8Ω, rather than the original 16Ω speakers.
Do I have it right that using the AUX jack disconnects the 8Ω tap and it should be ok to use the AUX jack only?
/Max
Re: Peavey Classic VT output jacks
« Reply #1 on: July 13, 2024, 07:03:00 am »
the AUX does disconnect the main speaker, however the AUX tap is 4 ohms, so you need 2 of your 12"-8ohms in parallel for 4 ohms
« Reply #2 on: July 13, 2024, 07:04:29 am »
your schematic shows the Main speaker tap IS 8ohms
« Reply #3 on: July 13, 2024, 07:07:54 am »
Yeah, it's a 212 wired in parallel. So 2 8Ω speakers in parallel wired to the 4Ω tap is what I plan to use.
Thanks 👍
