July 25, 2026, 07:40:08 am
Hoffman Amps Forum image Author Topic: Correct LaMar Pot  (Read 4734 times)
Offline dude
Correct LaMar Pot
« on: July 15, 2024, 12:58:23 pm »
In a 6V6 Plexi model1987, adding a LaMar master, would a dual pot replacing the grids that are 100k and using 2.2M safety R’s, be Liner or Audio taper?
Using 220k grids, l assume dual 250k is good,  can’t remember if A or B taper. Doing a google search, it’s six to one, half dozen to the other..?
Mark Huss’s original 6V6 Plexi he used 100 grids to 6V6s, just wondering opinions.
Any info on this much appreciated.
EDIT: use KL pots, for best results, more gradual cut.
« Last Edit: July 15, 2024, 02:09:40 pm by dude »
Offline Latole
Re: Correct LaMar Pot
« Reply #1 on: July 16, 2024, 03:25:18 am »
I use 500 k dual A ( audio ) pots
Offline dude
« Reply #2 on: July 16, 2024, 10:25:15 am »
A while back the the guys talked about Liner vs Audio Pots for a La Mar MV at the Metro forum, half said KL, half KA...?
One other question, I have built a 6V6 Plexi from an AO-43 chassis, Sluckey's schematic basically.  Mark Huss who I think was first to try this this used 100K ohms grids to power tube, most other use 220K, what is the difference in tone or the like?
Second, I added a switch to change to Cathode Bias on one of my 6V6 Plexi's, I like the two choices. Can I install a La Mar Master in this 6V6 Plexi without any issues when switch to the cathode Bias mode..?
Offline dude
« Reply #3 on: July 16, 2024, 02:52:24 pm »
I can’t see any reason that cathode bias would cause an issue. Just was making sure l was thinking correctly.
Offline Latole
« Reply #4 on: July 16, 2024, 03:00:50 pm »
Master Volume work as well  in cathode or fixed bias
