September 08, 2026, 03:27:27 pm
Hoffman Amps Forum image Author Topic: somedays  (Read 5255 times)
somedays
« on: July 16, 2024, 07:16:09 pm »
about midnight last, a micro burst hit, blew my window fan 3FT into the room, n this.  I've "studied" how to drop that tree for about a year, n a helping "HAND" takes the guess work outta it.  anything left for 180 degrees n the house would took a hit.  right, the tank mighta ruptured.
the in-feed copper, I ran in ~~'97, was screeched banjo tight, pulled regulator loose from tank, no leaks! (pic after tank guys cut line n tagged out tank)
thanks to the County guys and front-end loader, road cleared, cut'n at leisure!
Offline Platefire
Re: somedays
« Reply #1 on: July 17, 2024, 04:58:05 pm »
Yelp, be thankful! Could of been really bad.
I've got a huge Oak within about 15' of the house.  :help:
On the right track now<><
Re: somedays
« Reply #2 on: July 17, 2024, 09:14:54 pm »
15' is close,
I've taken out all the big trees < 50' from house over the last 4 years, this problem was the last.  Got 1 more inside 50' but it's "aimed" away from all the structures, probably drop it this fall n hire the neighbor to board it out, (he works cheap:) blue spruce about 20" diameter n 60' tall n straight
Re: somedays
« Reply #3 on: July 17, 2024, 09:34:54 pm »
dude  you could sell that spruce wood to geetar companies..
Re: somedays
« Reply #4 on: July 25, 2024, 04:51:18 pm »
You can be the front man, i'll take 10%  :laugh:
got ttttthhhhiiiisssss close n HE ......had other plans.  Just started a cut n the trunk moved, I moved, walla, back from whence it came!!!!
least the house is no longer in danger, I have this year, next year, and 1/2 the year after worth of wood, so I think plumbing my summer kitchen is in order!
