August 29, 2026, 09:11:36 pm
Hoffman Amps Forum image Author Topic: ½ 12AX7, ½ 12AU7 in one tube.  (Read 5329 times)
Offline jeff
  • Need input
« on: July 24, 2024, 06:44:43 pm »
Hi guys,
I'm looking for a 9pin tube that is ½12AX7 ½12AU7.
I think 7247 is one, are there others?
Don't care which side is which, or if pinout is scrambled(vs 12AX7) new build so any 9pin AX/AU's you know of.
Thanks.
Jeff
Offline Jonas
Re: ½ 12AX7, ½ 12AU7 in one tube.
« Reply #1 on: July 24, 2024, 07:00:58 pm »
Yes 7247 or 12DW7 is what you are looking for.
pins 1, 2, and 3 are the AU half (amplification factor 20)
pins 6, 7, and 8 are the AX half (amplification factor 100)
JJ makes the ECC832 which is also a dissimilar dual triode but the pin out is reversed in that 6, 7, and 8 are the AU half
There are other dissimilar dual triode but I don't recall one in which the amplification factor difference between the two halves were as "dissimilar" to the 7247
hope this helps....
Offline Jonas
Offline jeff
  • Need input
« Reply #3 on: July 24, 2024, 07:23:47 pm »
Offline stratomaster
  • Don't guess, measure.
« Reply #4 on: July 25, 2024, 08:26:58 pm »
The JJ ECC832 and ECC823 both exist. They are mirror images of each other. I want to say (from memory) the former is equivalent to the 12DW7, but it would be best to consult the datasheet prior to purchase.
