July 25, 2026, 02:39:22 pm
Hoffman Amps Forum image Author Topic: deluxe reverb II volume/channel switching pot  (Read 10130 times)
Offline dsones
« on: July 30, 2024, 07:25:48 pm »
I can't figure out how the volume/channel switching pot works from looking at the schematic or wiring diagram.  I'm trying to build a deluxe reverb II clone.  What current manufactured pot could be used for the volume/channel switching pot?  Thanks
Offline AlNewman
Re: deluxe reverb II volume/channel switching pot
« Reply #1 on: July 30, 2024, 08:13:09 pm »
Can you post the schematic?
Offline dsones
« Reply #2 on: July 30, 2024, 11:17:13 pm »
I've added an attachment (partslist (1)) with the schematic
Offline AlNewman
Offline Latole
« Reply #4 on: July 31, 2024, 02:46:29 am »
Is it this one ?  1 meg with SPDT switch.
See Antiques Electronics/ tubesandmore
« Last Edit: July 31, 2024, 02:57:49 am by Latole »
Offline Latole
Offline Latole
« Reply #7 on: July 31, 2024, 05:31:53 am »
Could you tell us why you chose to build this particular amp model ?
It's not an easy one, and you don't seem to have much experience.
Offline dsones
« Reply #8 on: July 31, 2024, 10:57:16 am »
I chose to build this amp because it has reverb, two channels, and is similar in sound to my champ II which I love.  I've built about 10 vintage amps (champ, princeton, bassman, mojotone studio one, some of the rob robinette micro amps, etc.) without any problems.  The deluxe reverb II has some components I haven't come across before.
Offline Latole
« Reply #9 on: July 31, 2024, 11:00:43 am »
Thank's for the answer.
 You have the knowledge to built this amp .
What do you think about the 1 meg pot SPDT I shoe you ?
Offline dsones
« Reply #10 on: July 31, 2024, 01:27:13 pm »
In the parts list it says '1 mj 20% w/spdt switch -- volume/channel select
Offline Latole
Offline Latole
« Reply #13 on: July 31, 2024, 01:50:43 pm »
See schematic. I show you a one will fit
Original part number are never useful.
« Reply #14 on: July 31, 2024, 02:09:23 pm »
You can use a the DPDT switch
The problem with it is it has a 7mm bushing  so it would work fine if you haven't drilled a hole yet,  if the mounting hole is already drilled and is for a 3/8 bushing then you will have to get creative.
Offline Latole
« Reply #15 on: July 31, 2024, 02:35:18 pm »
You are talking about the 1 meg volume with DPDT.
With more search can we found a 3/8 size ?
« Last Edit: July 31, 2024, 02:38:09 pm by Latole »
Offline AlNewman
« Reply #16 on: July 31, 2024, 07:59:36 pm »
Not IMO, it is a spst
My bad, you are correct.
« Reply #17 on: August 01, 2024, 11:40:44 am »
If you'all are talking about the channel switch  I believe it is this.
Offline Latole
« Reply #18 on: August 01, 2024, 12:12:11 pm »
https://nextgenguitars.ca/products/cts-push-pull-a1m-solid-shaft-pot-aluminum-shaft.html
Likely something like this
My bad, you are right
Update ; amp need a SPDT not SPST like this one
« Last Edit: August 01, 2024, 01:22:44 pm by Latole »
« Reply #19 on: August 01, 2024, 12:27:22 pm »
No that won't work for the channel switching. That is a SPST   what he needs for the channel switch is a 1M pot with either a SPDT switch or a DPDT switch we talked about above.
Latole you posted the CED/AES page above that has the correct pot w/switch and I mentioned it has a 7mm bushing   its the right part if it can be mounted on the chassis.
https://www.tubesandmore.com/products/potentiometer-alpha-1m-audio-7mm-bushing-dpdt-switch
note; CE Distribution, Antique Electronic Supply and TubesandMore  are all the same company.
« Last Edit: August 01, 2024, 12:36:09 pm by mresistor »
Offline AlNewman
