September 08, 2026, 05:48:26 pm
Hoffman Amps Forum image Author Topic: hotdog water Bugera G5 infinium repair  (Read 5541 times)
Offline fossilshark
  • No life til' leather
« on: August 03, 2024, 01:23:04 pm »
Hi all, I know its a little disrespectful to consider this a tube amp but it the output section does technically have a tube so  :icon_biggrin:
If I crank the volume and gain and strum really hard i get a few farts out of it but thats about it. I am measuring 200v across R201 and 0v across R202. both resistors read 22k but R201 has some heat discoloration. When measured against ground both resistors have 344v where V2+ is connected.
I am leaning towards a bad MOSFET but I just wanted to double check with you guys before I go ordering parts.
~SNOWBLIND~
Offline Latole
Re: hotdog water Bugera G5 infinium repair
« Reply #1 on: August 04, 2024, 03:15:56 am »
Read voltage from the ground, not across
Complete schematic, see answer #10
https://music-electronics-forum.com/forum/schematic-requests/42338-links-to-bugera-schematics
