September 08, 2026, 04:43:21 pm
Hoffman Amps Forum image Author Topic: 1974 Fender Twin Reverb Silverface Tremolo not working  (Read 6695 times)
Offline rustyadams
« on: August 15, 2024, 01:50:18 pm »
Help! Tremolo is not working. I replaced the opto coupler (roach) and still nothing.
I have swapped tubes V1 with V5 no change. Could bad capacitors cause this to no longer work?
I've attached the schematic for this circuit. Any suggestions?
Re: 1974 Fender Twin Reverb Silverface Tremolo not working
« Reply #1 on: August 15, 2024, 02:37:19 pm »
how close are V5s VDC readings to those on the schematic?
« Reply #2 on: August 15, 2024, 03:42:15 pm »
Oops  was thinking reverb  LOL   ok   have you tried a footswitch?
« Last Edit: August 15, 2024, 03:56:28 pm by mresistor »
Offline rustyadams
« Reply #3 on: August 15, 2024, 03:59:23 pm »
using a digital voltmeter V5 voltages : Pin 1 275-284 VDC    Pin 6 : just flashing OL not getting a reading
Have checked out the footswitch and it is good, also tried another cable with leads shorter just to be sure
Does tremolo rely on the reverb tank?  I have the reverb with the red dot going into the reverb input
« Reply #4 on: August 15, 2024, 04:01:04 pm »
sorry Rusty  read my post again..      old person here..  sorry  I've never seen the tremolo capacitors go bad
what model twin is it? probably doesn't matter concerning the trem circuit    here's schematic for 100w twin   https://el34world.com/charts/Schematics/files/Fender/Fender_twin_reverb_sf_100_schem.pdf
« Last Edit: August 15, 2024, 04:05:00 pm by mresistor »
« Reply #5 on: August 15, 2024, 05:37:43 pm »
the oscillator caps can be problematic, how many tubes have you rolled through?  Trem needs a solid tube
Offline stratomaster
  • Don't guess, measure.
« Reply #6 on: August 15, 2024, 05:58:53 pm »
How about the cathodes?
Offline rustyadams
« Reply #7 on: August 15, 2024, 06:21:58 pm »
not good... cathodes are at 0 V
« Reply #8 on: August 15, 2024, 06:44:45 pm »
That means a short. Lift the caps and remeasure.  The trem won't work, but it'll rule them out.
Offline rustyadams
« Reply #9 on: August 16, 2024, 04:32:07 pm »
Thanks for all the replies. I had a 12AX7 from another amp, I replaced it with that and it works. Noticed that the tube that was in there is a ECC83S.. not sure if that is the same as a 12AX7.
Anyway I took out the 12AX7 and put the original  ECC83S back in. And it works! Could it be dirty contacts in the socket? should I replace socket or try to clean it?
« Reply #10 on: August 16, 2024, 09:38:40 pm »
clean it
