September 08, 2026, 05:48:35 pm
Hoffman Amps Forum image Author Topic: cap can question  (Read 6239 times)
Offline joesatch
  • save me from myself.
cap can question
« on: August 18, 2024, 08:19:24 am »
can a 50 + 50uf cap can have the two sections wired in series? i'm guessing no since they share the same ground.  So when folks tie the two + leads together they are paralleling the two sections to get double capacitance with the same voltage?
« Last Edit: August 18, 2024, 09:15:37 am by joesatch »
Re: cap can question
« Reply #1 on: August 18, 2024, 09:33:33 am »
No is correct
"caps in parallel are like resistors in series"
so double the capacitance (think cap plate surface area)
Needs a double-check but think; "voltage is halved"
Offline dwinstonwood
« Reply #2 on: August 18, 2024, 10:05:10 am »
oops, never mind! deleted.
Offline joesatch
« Reply #3 on: August 18, 2024, 10:44:49 am »
well imma cut open this cap can in the hopes there are two smaller caps inside i can pull out and wire in series.
« Reply #4 on: August 18, 2024, 12:00:33 pm »
what's your end-game?  Higher voltage rating?
Offline Carlsoti
« Reply #5 on: August 18, 2024, 01:16:47 pm »
Vintage can caps are layers of various materials rolled into a cylinder, impregnated with electrolytic material, then stuffed in a can and sealed up, not just a couple smaller caps stuffed in the can. Some newer vintage-style replacements might be that way, though.
Offline stratomaster
  • Don't guess, measure.
« Reply #6 on: August 18, 2024, 01:41:40 pm »
Just add a 2nd cap in series. A 100-220μF at 160v is relatively small. Add appropriate totem pole resistors to ensure voltage rating isn't exceeded.  Take a look at the reservoir cap on the Deluxe Reverb reissue schematic.
No need to cut a cap open.
« Last Edit: August 18, 2024, 01:47:43 pm by kagliostro »
