September 08, 2026, 04:42:31 pm
Hoffman Amps Forum image Author Topic: Fender Princeton  (Read 22539 times)
Re: Fender Princeton
« Reply #50 on: September 17, 2024, 05:22:15 pm »
And that's with all new B+ filter caps?
Because that's still a little low.
Offline stratomaster
  • Don't guess, measure.
« Reply #51 on: September 18, 2024, 12:41:02 am »
Just put in new 5u4 E H tube
Voltages reciter pin 8 397 vdc
v6 pin4=396vdc pin3=362
V5 pin4=363vdc pin3=365
Bias v5 -30.4 v6 -30.5
Amp sounds pretty good to me
What do you think?
Your pin 4 measurements should be identical.  Pin 3 can vary a few volts from each other, but not the screen, and definitely not a 33v difference tube to tube. Recheck your voltages.
« Reply #52 on: September 18, 2024, 11:16:32 am »
I missed that on the pin 4.  :w2:
« Reply #53 on: September 18, 2024, 04:41:58 pm »
Yes, recheck ALL your voltages. Do this with ALL tubes in.
Rectifier tube, pin's 4 and 6 acv and pin's 2 and 8 dcv. Then the 6V6 tubes,
dcv- pins 3, plate
dcv- pins 4, screen.
« Last Edit: September 18, 2024, 10:27:27 pm by Willabe »
