September 08, 2026, 04:40:30 pm
Hoffman Amps Forum image Author Topic: Accidental Discovery - No Load Pot & Cut Control  (Read 4702 times)
Offline stratomaster
  • Don't guess, measure.
« on: September 14, 2024, 12:29:45 pm »
I accidentally discovered a great use for a no load pot I had in my stash.  I added a Cut control (variable resistor and cap across the grids of the output tubes, ala Vox) to my Marshall Origin 50.
I wanted it to be switchable out of the circuit and found a no load 250kA pot in my stash.  This fit the bill as at full the pot goes open--effectively out of circuit.  No switches needed.
Additionally, the "dead" lug acts as a convenient eyelet to anchor the cap and wire connection to the opposing grid signal. This bonus feature is missing on a traditional pot arrangement.
Wanted to pass this discovery on to the community. Do with it as you please.
Re: Accidental Discovery - No Load Pot & Cut Control
« Reply #1 on: September 14, 2024, 01:27:20 pm »
It's not too tricky to mod a regular pot to do this.
Just remember to mark it up as such, to avoid confusion later :)
Offline acheld
« Reply #2 on: September 14, 2024, 02:44:23 pm »
How does one do this?
« Reply #3 on: September 14, 2024, 03:43:50 pm »
You get invasive. Pry the fold over tabs and disassemble the pot.  Then cut away the very end of the track on the wafer.  Reassemble.
Hadn't done a no load, but have done a 25k bias pot by just swapping the 10k wafer for one from a different pot.
You'll want to be careful as you only get one shot, if that, with the metal tabs.
« Last Edit: September 14, 2024, 06:14:35 pm by stratomaster »
Offline dude
« Last Edit: September 14, 2024, 11:45:43 pm by dude »
